Tried to run a full system backup with FreeAgent Go. Backup failed and it looks like some files and programs were deleted from my computer in the process.
Tried to run full system back up on Dell Inspiron 1520 (finally upgrading to a new laptop). Per the log Copied 1637 files, 2268970030 bytes. Total files protected: 113130. Unable to backup 28 file(s) Backup completed Monday, March 17, 2014 2:15:02 PM However, it came up as failed. I tried to disconnect it at which point it put up a screen which was scrolling stating it was deleting files. HELP! I need those files back. What happened?
  • 3,320 Answers
Unless you asked the backup program to delete files it won't. The program may have deleted some files it created for its own use.
What error code did it give for failing the back up. How do you know you need the deleted files?
Posted on Apr 02, 2014
IB4G2008
  • 3587 Answers
SOURCE: cannot restore data from iomega backup pro
yes..that is quite the case. you may wish to do a restore all approach, perhaps to another drive, if you have that option.
Posted on Feb 11, 2008
IB4G2008
  • 3587 Answers
SOURCE: Sync software/empty folder/ slow backup/
hello frustrated one,
the back up feature is application dependent, not hardware dependent, misfortunately. Gotta love sales guys.
my understanding is that these will back up data files, not application files.
backup speed is dependent on how it's connected. in ascending order.
USB 2.0
Firewire
Ethernet
simple situation..just need to know what your connecting with.
Also, you may want to consider an online backup utility, as well. I use one from here
Posted on May 08, 2008
Marioland
  • 23 Answers
SOURCE: Corrupt File System
Well i guess that either your file system is corrupt or your disk is formatted into a filesystem that it's not supported by the backup programs. I don't really know what filesystem is your disk formatted into but usually the FAT32 and FAT16 are the most failsafe file systems for Windows.
So copy/paste the data you don't want to loose and then go to
My computer -> right click on the drive icon -> format and then choose fat 32. Then try backing up your laptop again.
Posted on May 29, 2008
  • 916 Answers
SOURCE: WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
Posted on Apr 29, 2009
SOURCE: I can't delete files from my Maxtor 3200 external hard drive
The other comments are not the easiest way to free up space on the drive. The reason you aren't seeing a change in free space is because of a drive error (probably unplugged without unmounting). So First open up disk utilities and fix the hard drive (should only take 1-2 min). After the drive is fixed select erase free space (zero out data is fine for now). This usually takes about 20 min for me with a 120 gig hard drive. This allows you to have the free space without having to move all of those files around (which for me would be a problem because I have 100 gigs used on my drive, which would take forever).
Posted on Dec 20, 2009
How do I Copy files from my hard drvie to the FreeAgent External for Back up
You can either manually copy files by launching windows explorer (right click on the start button, select "explore"), navigating to your files, select the files, hold down CTRL and then tap C to copy, and then navigate to the FreeAgent External Drive (It should be on the right side of Windows Explorer, named "Agent" or similar), and then hold CTRL, and tap the v button to paste.
Alternatively you can navigate to the FreeAgent drive, where there should be a backup program. Launch the program, enter in the details of what and when to backup, and let it run in the background.
Apr 07, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How to backup files and folders
did you install the software included on the seagate?
if not install it and you can setup the back up/schedule.
or you can use windows backup to schedule backups to the seagate drive.
Mar 05, 2011 | Seagate FreeAgent Pro 500GB External USB...
How do I manage and delete files on the iomega to make room for new backups?
when you plug in the drive it should mount it self and an external drive you can get to it by clicking on my computer and usually it will be labeled removable disk.
Mar 02, 2011 | Iomega 500GB Prestige USB 2.0 Portable...
Error (2013) whith Seagate Manager
Cause: File in history folder is corrupted or unmovable.
Solution: If an individual file is identified with the error, delete the affected file from x:\Seagate Backup\History folder on the external drive. If an individual file is not identified then it may be necessary to run Windows error checking on the external drive or delete the x:\Seagate Backup\History folder and run a fresh backup, if it can not be repaired.
Apr 12, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I am preparing to do a PC restore for a problem unrelated to Seagate products. Will FreeAgent C7200 back up my emails, one account in Outlook and and the other web based, so that they can be reinstalled?
You can backup all your programs in the free agent with the help of the software that is provided with the drive please read all the instructions very carefully like how to backup and restores the file from the drive before reinstalling the OS and remember there is always two options available one is file backup and another is system backup.
Mar 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent go status icon stays red what is the problem?
When a backup or sync has failed, the red icon continues to display until the next successful backup or sync. You can view the log file to determine why the backup failed.
Nov 11, 2009 | Seagate FreeAgent Pro 500GB External USB...
Running Windows 7 Home premium. External drive Verbatim USB 250 Silver is recognized, but, needs to be reformatted. I've tried to format (NTSF) using tool in Disk Management. Format runs forever and...
Hello and thank you for using Fixya's services.
This problem happens quite a bit with Windows Vista. It seems that Windows Vista puts a hidden file in the backup; which locks the device.
Open the external device (Windows 7 is fine). Click on "view hidden folders and files." Delete any hidden files you may have in the external.
Go back to "my computer" and right click on the external hard drive letter. Choose properties and security tab. Make your user-name as a main user (administrator) and disable the read only.
Reboot the computer and see if this works.
Please let me know if you have any questions.
Nov 04, 2009 | Office Equipment & Supplies
Help to backup full computer programs & docs with WD Passport 160
Try going to the "Computer" icon and look for the external drive. Open the ext. drive folder and look for the InstallSeagateManager icon, the Application one. Double-click on it and it will allow you to install the software to do a backup on your new computer. First thing you should see is the Language Selection screen. I think you can take it from there!
Sep 22, 2009 | Western Digital Passport (WDXMS1600) 160...
Hard drive thinks its full but its not
Does your computer have a backup and recovery program? We've found with some of our notebooks that if you allow the notebook to make a backup but don't specify where to do it, your hard drive makes a backup of the hard drive on the hard drive.
Oct 20, 2008 | Acer Aspire 3000 Notebook
Backup and recovery
Delete the System Recovery Files folder located at C:\System Recovery Files then try to run the backup.1.exe program again. I also found the you have to have the Backup.2.fbw file burned to a DVD before it will restore the files.
Rayna
Jun 10, 2008 | Microsoft MediaRecover File Recovery...
Computers & Internet Logo
David Payne
David Payne
