Question about Broksonic CTSGT8118T 13 in. TV/VCR Combo
What do i need to transfer a vhs tape to my computer
How to fix broken vhs tapes
If the problem is the shell of the cassette that is broken, simply buy a new blank VHS tape and remove carefully the screws underneath it. You can then take out the old tape and fit it in the new shell.
However if it's the tape itself, that more tricky. A tape split in two can be glued together using splicing tape. Don't ask me where you will get it though!!!
You will need to have to straight edges to "splice" it together.
Badly mangled tape is best cut out and the tape spliced together.
It's not a good idea to keep using any repaired tape though. As tape deposits can build up on video heads and knacker a video head. As these are VERY expensive to replace you don't want that! In fact I would transfer the tape via a computer or by a VHS to DVD recorder.
Mar 13, 2013 | Televison & Video
I want to trasfer my vhs tapes to a disc is this possible
You will need a VHS tape player, and a DVD recorder in order to transfer the content of your VHS tape to DVD. You can also use your computer to convert VHS to DVD. Here is an excellent site with in-depth information on converting VHS to DVD: http://www.vhstodvd.com/
Mar 09, 2011 | JVC Video Cameras
Conversion vhs to dvd
I can only offer you 1 option for this case.
In converting the VHS video tape to DVD you can use computer. All you need to have is the VHS player with RCA audio video cables. Then a computer that has video capture card or USB capture card. This will take time but you can just transfer all the copyrighted videos to DVD and to computer data (post to internet)
*Needs realtime transfer VHS to Computer with the prefered resolution option.
*Burn to DVD, it will depends on your DVD drive speed.
Mar 26, 2010 | Video Cameras
VHS tape created in France
If it was made with the French standard you will need a machine capable of playing SECAM formats. Your cheapest way to go is to locate a video transfer business which deals in tape transfer. They should have the equipment which can play the tape and record it in a format which you can use. Cost should not be that much.
hardrocko
Thanks for using FixYa
Jan 12, 2010 | TDK T 120HS VHS Tape
How do i go about transfering vhs-c video from an
You have several options. But important one to understand is the limitations of a PIII computer like Armada e500. You may not have enough grunt to convert stuff, even after buying the necessary video capture devices which work on USB.
Also I am assuming you either have the jvc camcorder still available or atleast have a VHS-C to VHS adapter to play the tapes on a standard VHS tape player.
Unless you are having a lot tapes and need editing while converting, your better bet might be to go to one of the shops that convert these tapes on to DVD or a suitable flash drive which might work out cheaper and quicker.
The last time I did this thing (quality of my VHS-C tapes was bad) I bought a Samsung combined VHS Video / DVD recorder and used the dubbing feature to burn DVDs. Cost me about $150 a year ago. I was able to do some editing on the way as I was connected to the TV screen as well. Saved me the hassles of dealling with the PC type video capture devices and software.
Dec 25, 2009 | JVC S-VHS Tapes (ST120SVDU2) S-VHS Tape
I am attempting to convert a vhs tape to dvd. I have purchased a converter and cable to connect with computer via USB all seems OK cannot find if or where it transfers
You probably need some sort of media player or something that will allow your vcr to play the tapes through the computer and will allow you to save it in some type of format such as windows media player or something. After that you should be able to transfer it to DVD with a program such as roxio. To see if your computer is detecting your vcr hook it up go to my computer and look for a new storage device.
Aug 01, 2009 | ION Audio VCR 2 PC USB VHS Video to...
Problems transferring entire VHS tape contents
Just continue what your doing in previous just save the remaining minutes maybe the limits was approaches.
May 18, 2009 | Diamond Multimedia ( VC500) Video Capture
Panasonic DMR-ES40V DVD-Video, Transfering of..
ok,you need to prepare your VHS tape and put to what portion of it you want to transfer.but, you will need a cd/dvd writer.it is used to record whatever you want to record.you need a computer to do this.it's complex but if you get the hang of it, it's very easy.
May 07, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
I want to transfer from vhs to dvd. Video tape is protected.
You can copy VHS tapes that cannot be done on standard equipment. You can buy EZGRABBER to down load VHS tapes to your hard drive, then use a program likePower Produucer to go from your hard drive to a recordable DVD unit if you have one installed in your computer
Apr 21, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
Broksonic CTSGT8118T 13 in. TV/VCR Combo Logo
22 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
