Question about Jandy Pool & Spa
Pump does not come on when it is scheduled to come on.
  • Bill Jordan Mar 20, 2014
    Hi Tina Rosso, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Top Expert:
  • Jandy Master
  • 5,779 Answers
Make sure pump is assigned to an aux and you have to assign the aux to come on if smart pump you have to assign 1 thru however many you have
Posted on Mar 11, 2015
The motor get hot and it use alot of gas!!
It must be time to check on your regular maintenance schedule. So start from the timing of the engine, check for the coolant , the water pump, and definetely the fuel pump. The engine will need a trimming for fuel. Since the mileage is not mentioned , you must check specifically on your maintenance schedules. Hope you get this corrected. good day
Aug 16, 2010 | 1996 GMC Jimmy
Please give me the start up directions for the intex saltwater pool system
hold arrow down till beep hold arrow up till beep press up arrow to desired amount of hours then hold both arrows down till beep to lock in schedule. It will run that schedule every day.
Jun 06, 2010 | Intex Automatic Salt Water System for ...
Can i do a tune up or is there extra precautions i have to take in doin so?
Hello- Basic maintenance on your CL consists of either normal or scheduled. Normal is air filter/oil/fluids/plugs/brakes/tires, etc. Scheduled service is 90/180/270k miles---- Timing belt/water pump/tensioner/thermostat/coolant/belts/trans oil/brake fluid. Parts for 90k are about 300$.- Buy timing belt/water pump/tensioner from Acura. Use only NGK plugs. Let me know if this info helps- have more if you need it.- Thanks- ED
Mar 03, 2010 | 1999 Acura CL
Maintenance schedule
If the water pump is driven by the timing belt replace it and anything else that is driven by the timing belt(idlers and tensioner) , Also replace the camshaft and crankshaft oil seals while your there.
Never hurts to flush the cooling system and add fresh coolant/anti-freeze.
Hope this helps
Jun 26, 2009 | 2004 Hyundai Elantra
Can't find the fuel filter in a 2005 kia optima
klaudie: This car does not really get serviced very often unless there are contaminants in the tank. I checked the Kia factory maintenance schedule and there is NO reference to fuel filter replacement. It seems that many manufacturers are now just putting screens or socks in the tanks before the fuel pump and no longer use fuel filters. KIA just puts a fine screen before the fuel pump. The pump is in the fuel tank which warrants it's removal to access the pump.
A strong word of advise of this engine!!!!!
Do NOT let the timing belt go beyond 60,000 miles. I could find no reference in Kia's maintenance schedule for timing belt replacement. According to them it's a judgment call by the tech! THAT IS TOTAL INSANITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If the belt breaks in this engine you will trash the upper end of the motor and be spending big bucks! Nearly all automotive manufacturers had scheduled timing belt replacements at 60,000 miles and suddenly a lot of them just extended the time and distance, but the part numbers, manufacturers and designs didn't appear to have changed. I have had many cars in my shop where people did not heed my warning. Some get lucky and others have to hock their kids fo afford the cost of their negligence.
Mar 17, 2009 | 2006 Kia Optima
Scheduled maintenance
Jacuzzi pumps are very reliable. If you keep the debris out of it, you should be fine. It will let you know when it needs help... a squealing bearing immediately comes to mind.
Nov 25, 2008 | Jacuzzi Pool & Spa
Maintenance schedule corolla 110 1996
change fuel filter and stick an airline down the feed pipe to the filter to blow out the gauze filter in the tank ,remove the filler cap first though ,if none of this works remove the injector pump and take it to diesel specialist
Nov 08, 2008 | 1996 Toyota Corolla
Pool & Spa Logo
54 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
