Question about Electrical Supplies
Fixture not working after bulb change
The bulbs blew out. I purchased new florescent bulbs but the light will not come on
  • 3,287 Answers
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Posted on Mar 18, 2014
3 Suggested Answers
  • 52 Answers
SOURCE: Should a twoway room fixture actually be a three way ?!?!
The leviton 5603 switch described in the header is a three way wall switch.
I think what you are asking about is what electricians refer to as a "three way switch"
This is basically one outlet or device connected to two wall switches. 1) switch, 2) outlet or light fixture, and 3) another wall switch, three components, thus a three way switch. Installing or converting a fixture or outlet from standard to three way is something i would recommend contracting out to a licensed electrician. Unless you are really comfortable with electrical work.
It is a possibility that your wall outlets are already set up to be a three way switch. A lot of houses have this feature especially at the top and bottom of a stairway, depending on when your house was built. If it is not already configured it could mean stringing new wire behind the drywall which most often means tearing some of the drywall out so that it can be stapled to the studs and meet required building codes.
If, before the changes were made, you were able to turn on the light from either of the wall switches then you will only need to connect the wiring correctly at each of the components.
If you google 3-way switch you will find a ton of great info and wiring diagrams that will help you see exactly what goes into making them work, since they can be wired more than one way. It could help you decide whether or not it is a job you want to tackle on your own or if you want to hire a contractor.
Let me know if I didn't explain something clearly.
Posted on Mar 01, 2010
SOURCE: I have installed (or tried to) three different
The Leviton PR180 is a motion detector, or occupancy detector.
It senses infrared heat from a person's body.
I am looking at the manual from Leviton.
Maybe this will help:
There is a small adjustment screw under the wallplate where you can adjust light sensitivity.
Use fingernail or small screwdriver.
Turn control towards the "-" sign and lights will turn on in 'less lighting conditions'
I will be here for a few more hours.
Add a comment and I will help further is needed
Posted on Nov 05, 2010
Can I replace the 13 watt CFL bulbs in my fan light fixture with a higher watt bulb
The bulb fixture itself should tell you what the max wattage is that you can put in there but they are normally at a 60watt limit.
Feb 25, 2015 | Hampton Bay Dryers
The light in our hot tub is not working..do you know how to install the new "clip" which we purchased from Beachcomber???
The light bulb just plugs into the fixture that is attached to the wires. Now, the fixture is installed from the back of the white niche by inserting it and giving it a quarter turn to the right. Next time you need a bulb, for a few extra dollars more you can upgrade to a color changing LED bulb. Find one at poolsupply1.com
Nov 01, 2014 | Pool & Spa
My motion security light keeps blowing only the left side bulb.
I assume you mean that the light bulb is failing. This can be caused by a faulty connection at the base of the lamp which causes the bulb to heat at the connection point. Remove the bulb and (with power off!) examine and clean the bulb socket.
Jan 19, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Florescent light tubes wont come out
If they are slotted fixtures and pins on the ends of the tubes, turn off the power and push the fixture slots off the tube. The heat generated may have warped the ends towards the tube. Use a flat screwdriver -carefully and put it between the end and the fixture slot. Make sure that the tube is in the vertical position with the pins and it should come out
Jan 07, 2014 | Home
Have 3- 13 watt mini spiral bulbs on fixture. When switch in auto mode, lights hum, flicker and not maximum brightness. When switched to on position, lights stop flickering and humming. Full brightness as...
-Replace the compact florescent bulbs with regular incandescent bulbs and see if problem continues.
-Lighting controls are made for different kinds of bulbs.
-Your package should say what the watt rating and type of bulb.
According to the PR180 manual:
-I am looking at the Leviton PR180 occupancy sensor manual, and the PR180 sell-sheet, and these documents say for incandescent and fluorescent (rapid-start magnetic ballast only).
-Compact fluorescent are supposed to have a magnetic ballast.
-The manual does not specifically say it works with 'compact fluorescent'
-The manual does not say there is a minimum amount of wattage either. Some controls will not work correctly if the overall wattage is low. Your overall wattage is 39watts.
Read the product package (if this is a new installation and you have the package)
Try the incandescent bulbs.
If the PR180 is not your product, add a comment with product number and I'll look for information
Nov 06, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
How do you take the light fixture apart to fix the balace?
You may find that a new fixture is the easier and cheaper way to go as some ballast can be expensive and hard to find the matching style. A similar style fixture at Home Depot or Lowes cost, in a 2 pack about $18.00. Add a CF bulb to it for another $4.00 and you have a decorative similar fixture. Some ballast cost anywhere from $9.00-$50.00. If you wish to replace the ballast: (turn off the power) remove the globe, remove the existing florescent bulb, take the fixture off the ceiling (usually two screws) remove the wire nuts, make a small diagram of the existing wires and the color codes, take the ballast to the Home Depot or Lowes first, match the ballast. Now reverse the process to replace the fixture. Hope this helps. Good Luck!
Douglas
Oct 31, 2010 | Universal Lighting and Decor White...
Changing headlights
Suggest changing the clip fastener, or failing that, find some adaptation.
Review this information: ZJ-Secc-8L-Lamps (Page 5 and next)
Good luck, and remember rated this help.
Aug 20, 2009 | 2000 Jeep Grand Cherokee
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Light bulbs burn out after a few days in garage door opener, craftsman 1/2 HP double lights. have used every kind out there, specially made for garage doors, etc.
Try REVEAL brand DOUBLE LIFE ceiling fan light bulbs, available from HOME DEPOT. The filament in those bulbs is much thicker than any others, and the one I installed on my own Sears GDO has lasted 3 months so far, compared to one week for others I have tried.
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
PT Cruiser Brake Light
The bulb in the rear light has burned out and to replace it follow these instructions: 1) go to your owner's manual to find out the part number. You can find and purchase the replacement bulb at Target, any auto parts store and even at Walmart for under $4.00; 2) pop open the trunk door; 3) get a phillips screw driver and unscrew the 2 screws holding the rear brake light fixture to your car body; 4) as soon as you turn over the fixture you'll see where to pull out the burned out bulb and replace it with the new one(s). Good luck!
Jul 14, 2008 | 2006 Chrysler PT Cruiser
Electrical Supplies Logo
196 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
