Question about Refrigerators
Refrigerator makes knocking noise when door is opened
I have a Whirlpool side by side refrigerator. It has recently started making a knocking noise that seems to be triggered by the refrigerator side door being opened. The knocking will continue for approximately 10-15 seconds after door closing. The only time the knocking does not occur is when the fan is running when the door is opened. I have pulled the unit out and cleaned dust since the noise has begun. No difference noticed. Fridge seems to be cooling fine.
  • 74 Answers
SOURCE: side by side GE refrigerator psf26pgta
The fan should be a standard 12v DC computer style fan , test that you are getting voltage to the fan connector . You should also be able to get the fan to run by connecting it to a suitable supply . Once you have eliminated the possibility of fan failure then it gets more involved.
Posted on Aug 28, 2008
ngafm
  • 166 Answers
SOURCE: Whirlpool Side By Side Refrigerator
1. How do I get repairs done under warranty?
* If your refrigerator is under warranty, you must use an Authorized Service Company.
An Authorized Service Company can be found by using our Service Locator. Enter your zip code on the Service Locator to get a listing of available service companies in your area.
Back
2. How do I order parts?
* Parts can be ordered through an Authorized Frigidaire Parts Distributor.
An Authorized Parts Distributor can be found by using our Parts Distributor Locator. Enter your zip code on the Parts Distributor Locator to get a listing of distributors in your area.
* You can call our toll-free number to order parts (credit card orders only.)
Please call 800-599-7569 M-F 9:30am - 5:30pm.
Back
3. Noises / Sounds.
* Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises.
The following can be sources of these noises:
1. Dish vibrating on shelf - move dish slightly.
2. Floor is uneven or cannot adequately support refrigerator. Use shims or extra support.
3. Items on top of refrigerator are rocking. Place a pad under the item or remove.
4. Refrigerator is not level. Adjust leveling legs or rollers as needed. Add shims in the back if floor is not level from front to back.
5. Refrigerator is touching wall or cabinets. See your owner's manual for space requirements.
* Snapping or clicking sound.
If your refrigerator is equipped with an ice maker the water valve will snap on when the ice maker is calling for water. This is normal. In some cases you may not have the water connected to your ice maker and the sound will be greater. In these cases, pull the wire signal arm (bail arm) on the ice maker in the up position to turn your ice maker off until the water supply line is installed.
Back
4. Taste and odors.
* Ice or food has a bad taste or odor.
Ice and uncovered foods can pick up odors or taste from strong smelling foods in the refrigerator or freezer. Cover foods tightly and discard old ice.
* Ice tastes like plastic.
Plastic water lines will give off a taste when first used. It takes one or two containers of ice for plastic to stop leeching. Discard initial container of ice after installation.
Back
5. Ice maker - not making any ice.
* Freezer may not be cold enough.
Temperature must be 5 F. or colder to work properly.
* Water supply valve may be blocked or restricted.
Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
* Water supply valve may not be open.
Find and open the supply valve.
* Wire signal arm on ice maker is in the up position.
This position shuts off the ice maker. Pull wire arm (bail arm) down to start ice making.
Back
Posted on Sep 05, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
SOURCE: Right Door is making loud popping noise
replace the door cam assy. and door stop.
Posted on Nov 05, 2008
  • 306 Answers
SOURCE: Clicking noise coming from whirlpool refrigerator
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Jan 18, 2009
Whirlpool American side by side fridge/freezer is making a clicking noise. Sometimes it lasts a few minutes and other times it can last over an hour. If I open the doors its stops and as soon as I close...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | Whirlpool ED2FHEXN Side by Side...
Knocking noise coming from bottom of refrigerator
check the compressor for operation adn check the fan in the back of unit to make sure it is running...whirlpool units are notorious for compressor relay failure normally they click in and out every few minutes... if it is a knocking noise and continuous make sure compressor is not trying to start and sitting there shaking... normally it will stop after a few minutes and then start again....
Jan 25, 2011 | Whirlpool GS6NBEXRS Side by Side...
Load knocking noise
these high efficiency compressors make noise when they are in defrost..you will sometimes hear water running, or tapping noise or even a popping noise. if it happens when its off in defrost.. it will only happen three or four times per day as this is the defrost frequency and nothing can be done without securing the heat exchanger to the suction line ..sometimes these come loose...
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Makes loud knocking noise under refrigerater side
Hi, Does this noise accure when the compressor is shuting off?
May 12, 2009 | Whirlpool ED5VHGXM Side by Side...
Lights out inside refrigerarator and making noises
bad door switch unplug and pry out switch and replace the sound you are hearing are wires burning
Apr 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Refrigerator Buzzing sound when motor is on
some thing could be toching the fan at the back of the fridge or freeze fan making noise
Apr 02, 2009 | Refrigerators
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool side by side 2005...make to much noice
freon does not make a noise a compressor can if this noise is a knock then it is coming from the compressor and to solve it the compressor has to be changed
Apr 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
