Question about Universal Remote Control MX-350 LCD Remote Control
It won't respond unless i go down stairs and point it at the box
I need the exact location of the IR sensor on the front panel of a Motorola DCH6416 cable box.
Do this like mine sweeping. Grab the remote and put it right up to the front of the box. Press the channel up or down keys as you move the remote across the front of the box. You'll get to a point where the box responds well. Then as you go past the point the box will stop reacting so well. Home in to the point where the box responds well. That's your point for the blaster.
Sep 14, 2014 | Arris Dch6416 Dual Tuner Hdtv Dvr Hdmi...
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Tectrix climbmax
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You can find some of the information on these machines with the link above. Without knowing your model and serial number, the below link is to one of the manuals we have available on our Website. http://www.sportsmith.net/images/product_support/tectrix/Manuals/P1303103%20-%20Climbmax%20Personal%20Manual.pdf
Apr 18, 2014 | Exercise & Fitness
Can't pick up signal on the other room for my dstv
chances are your problems lie with your connections themselves, most cases its with the splitter box if you are using one, if u are then rather remove the splitter box altogether, u will then need a set of RCA cables (the red white and yellow cables that come with DVD players) use these to connect the first point directly from the decoder to the TV using a free AV input behind the TV. form then on proceed to connect the cable going to the room directly to the RF OUT port behind the decoder (make sure the copper and aluminium wires dont end up touching, but use both, the copper on the inside and the alu on the steel outer casing) if this doesnt work check your connections and if all fails replace the cable as a last resort
Oct 08, 2009 | LG DR787T DVD Recorder
Up grading my system in a up stairs & down stairs house
Only use one router. At the point of entry of the internet service provider(dsl or cable) connect your wireless router.(prefer middle of house) If you need a repeater for your signal do so but I don't think you will need one with N technology.
Sep 01, 2009 | Linksys WRT160N Wireless Router
Miele Solaris won't turn on after falling down 1 stair.
there is no reset on this model. look @ your miele info & it shows you where it would be. I just had to look for mine when it would'nt start. mine ended up being cord winder kink affecting motor.
good luck
linda
Mar 15, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Stair Climbers screen won't work
Wide Ride Pedal CTGID0 Stair Climbers screen won't work
Dec 01, 2008 | Schwinn Wide Ride Pedal
Wiring a 3 way switch on 1 plate to 3 lights and 2 other switches
I have a light switch at the bottom of the stairs which works 2ways can be switched on and off up and down stairs and also an out side light on the same switch which I have messed up and would like a picture of the way it should be connected.
Sep 21, 2008 | Electrical Supplies
Measuring for stair carpet
measure the length of the tread and riser, combined. Typically this will be 17 inches or so. Add at least an inch or two for good measure then, assuming all the stairs are the same, multiply by the number of stairs and, in most cases add for one additional riser. This is for straight stairs with no landings or turns. For pie-shaped stairs one needs to measure the longest points for the trad portions.
Sep 03, 2008 | Office Equipment & Supplies
Moving the TV
you should be fine as long as you don't drop it of course. you and turn and twist it any which way but id say measure the height of the tv because at some point you will have the top and bottom of the tv touching 2 different walls if im not mistaken
Feb 13, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Universal Remote Control MX-350 LCD Remote Control Logo
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
