Question about Dishwashers
Dishwasher blows out steam and has ruined wood floor in kitchen have to replace wood floor
Maytag dishwasher steams out on wood floor and I have to replace wood floor
  • 1,511 Answers
The door seals (Gaskets) surrounding the door are not tight. The door adjustment, is dependent on the tilt backward and height adjustment (adjusting levelers) on the corners. If the upper locking tab screwed to the counter tops underside is loose or misaligned, bent, or broken, the door won't close fully and cause the same problems.
Posted on Mar 18, 2014
tattootech2
  • 72 Answers
SOURCE: I have a Frigidaire dishwasher that I have had for
I would check to make sure that the top spray arm wasn't over tightened when it was installed. That spray arm threads onto a plastic supply tube which is easy to strip, which will cause it not to tighten properly and leak down the side of the dishwasher and acros the floor.
Posted on Apr 08, 2010
SOURCE: LG dishwasher is dripping water from vent onto floor
I have steam coming out during dry cycle wetting my floor. What is the kit that LG has developed and where can I get it?
Posted on Apr 27, 2010
SOURCE: My customer has a kenmore
This is NOT normal and should NEVER happen, there must be some sort of leak or the like from under the unit. Steam coming out, is very unusual, as steam is usually NOT generated by the unit, I suspect, that it is more condensation from under the unit that's more likely that any steam damage, as if it was steaming that would suggest that the water is Boiling or at least being heated to a steaming temperature, and water inside the unit, simply isn't heated up to this temperature, the water may be steaming, but it is not steam. well hopefully.. That's of course unless we had a fault that would overheat the water?
One does indeed require an out for all the fumes etc, however mostly all vapors are contained inside, and if there is any evident on the outside then we must suspect a hole or some way for the water to get out the bottom. Sometimes the Overflow tanks, can over fill, and then you can have water coming out indeed, usually though this is fairly evident, but it may have just been a drip drip drip... as they all soon add up...
If the floor has rotted out, then i would also wonder at the inside condition of the machine, and the bottom panel too.. it may have rusted almost right through? it needs to be checked too..
You need to perform a thorough check of the machine to assist i give you a link so you can download your service and repair manual. below.
http://appliancejunk.com/forums/index.php?topic=2933.0
Below, is a DIY self help website to assist you too.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Posted on Nov 15, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Maytag dishwasher
It is best to try a few different ones... different detergents work differently with the different dishwasher/water combo's... ya can never tell what the best soap will be till ya try them in your DW with your water...
Also get some TSP and add that it will help the soap work better...
DishwasherResidue and Film on Dishes
heatman101
Posted on May 04, 2011
  • 122 Answers
SOURCE: steam is leaking from the
Has steam of this nature been emitted when the unit was first in use ?
It might be that the thermostat is failing/faulty causing the unit to overheat the water. Most dishwashers do not heat the water to a level that would cause excessive steam.
Posted on Jun 08, 2011
Should the steam vent on top of Kitchenaid dishwasher be visible when door is latched or should it be jnder countertop completely?
unless you have a granite countertop I would say it needs to be seen wood getting steamed will rot out rapidly
Jan 16, 2016 | KitchenAid Dishwashers
15 yr old kitchenaid dishwasher leaving white steam marks on wood floor
Check your seals around the door, if that is where the steam marks are coming from. Rubber can easily be replaced
Mar 04, 2014 | KitchenAid Dishwashers
Steam is pouring out of the top right hand side of the dishwasher. It is ruining the underside of the countertop.
Its completly normal for the dishwasher to steam during the cycle. Some manufactures make a steam guard which is a piece of stainless steel and mounts to the underside of the countertop where the dishwasher is installed to prevent the steam from ruining the countertop. If ya can find a piece of stainless steel to mount there it will deflect the steam.is needs to be stainless since regular steel isn't stainless and would rust over time. Perhaps plexiglass would work too.
Gene
Aug 04, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
Steam is leaking from the side of my dishwasher, and ruining my unit
Jun 08, 2011 | Dishwashers
I have a Frigidaire dishwasher that I have had for a year and a half - 8 months ago it broke and leaked into my kitchen ruining my wood floor which had to be replaced. Shortly after that the top sprayer...
Mar 24, 2010 | Dishwashers
I have a Shark Steam mop and loved it for my kitchen vinyl floor. We just moved into a new home with hardwoods everywhere and I was wonder how well it worked on wood and laminated wood floors.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
It works great on hardwoods and laminate floors...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Feb 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Our dishwasher steam has expanded the wood chip at the edge of our countertop. how do we fix the formica countertop, would clamping it into place do the job? Would we need to heat the area first?
You cannot resize the wood once it has swelled. You have 2 choices: 1, replace the countertop with something more steam resistant or,2 remove the swelled area and replace the wood with pine or oak glued into place with moisture resistant adhesive.
Eric
Dec 30, 2009 | Amana 24 in. ADB2500AW Built-in Dishwasher
Steam eating my cabinet top up
You can buy a metal strip with a small angled edge to fit under the worktop above the dishwasher. I have one of these and it has protected the worktop for 10 years,
Dec 22, 2008 | Frigidaire 24 in. PLD2560LCC Energy...
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Water/steam coming out of top right side.
where you see the steam use electrical tape over that area and see if it stops.it does sound like a seal problem but another thing to check is to make sure the unit is level.
Aug 25, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
144 people viewed this question
Top Dishwashers Experts
Owen Barnes
