Question about Honeywell Humidifiers
WATER OVERFLOW AND DROP ON THE FLOOR
After 7 to 10 days, all water leaks on floor.
Does it get heated? If so, Heat makes filter dry and it starts to leak.
Mar 24, 2016 | Humidifiers
How much water gal/hr is reasonable to expect from the furnace humidifier overflow in "0 degree" farenheit outside to heat a 1500 square foot normal midwestern house to 72 degrees inside having a norm
There is no flow rating because it would depend on too many factors. What you do need to check is the float valve. The water valve is opening and closing like it should be but the reservoir is filling too much.
Jan 23, 2015 | Humidifiers
Water in carperting
this might sound stupid but is it pitched so that it drains outside instead of level or in towards the house?
May 17, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
Jan 02, 2010 | Aprilaire 550 Humidifier
Water spewing into the reservoir and ovrflowing
Sounds like you do not have an orifice in the water line to regulate the water pressure.
Feb 25, 2009 | Aprilaire 550 Humidifier
Honeywell HCM-305T Spits droplets rather than creating a mist.
Thanks for your question,
Sounds to me like you have something partially cloging the misting nozzle, if you can take the nozzle off, and check it I would bet there is something that got in there, if you cant, it might be better to just return the Humidifier where purchased for an exchange, if you can get the nozzle off, if you have a can of compressed air like they sell for dusting off computers, I would use a very short burst of that in the nozzle, and in the feed line, thanks again for your question, let me know how it works out,
mr.grzz
Jan 14, 2009 | Honeywell HCM-300T Humidifier
1 tank empties at once, overflow all over floor.
Ever find a solution to this? I had the same bug after 2 years working fine, felt stupid as I couldn't understand it. I replaced both tanks for no good reason then it worked fine, took it out this season and it's doing it again.
Dec 31, 2008 | Bemis 427 300 Humidifier
Waterflow
If the unit was installed with a saddle valve, which is most often the case, you could try turning down the water pressure by tightening the valve a bit. Just follow the copper water line from the humidifier back to the main water line and look for a little valve that you can turn. Try to tighten this enough so that you still have water flowing, but at the proper volume so that it doesn't overflow and splash all over.
Dec 16, 2008 | Aprilaire 600 Humidifier
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Humidifiers Logo
41 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
