Question about Craftsman Building Materials
My sears caftsman 10/2 12 volt sensor 2 charger stopped charging
4 Suggested Answers
frankzen
  • 19 Answers
SOURCE: Hi. I need a Sears Craftsman 16 volt battery
www.craftsmancordless.info
Posted on Apr 04, 2009
  • 8 Answers
SOURCE: charger not charging have 2 new chargers neither 1
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
Posted on Nov 17, 2009
emissionwiz
  • 75817 Answers
SOURCE: garage door opens only part
Hi
This may be just a matter of adjusting the safety limit switch rheostat at the rear of the opener motor. Here is the full set of instructions for proper adjustment.
Adjust garage door opener when your door is not working properly. There are certain components of your garage door opener that need adjusting to ensure that your door functions safely.
Things on Your Garage Door Opener That Need Adjustment
  • Limit
  • Force
  • Safety reverse
Step 1-How to the Limit
Turn the adjustment screw on the limit clockwise if the door doesn't fully close.
To open the door completely, adjust garage door opener by turning the limit counterclockwise.
Step 2-How to Adjust Garage Door Opener Force
If your door doesn't rise at least five feet when it is suppose to be opening, hold the bottom of the garage door while it is lowering. This will adjust the open force. For a door that doesn't reverse while closing hold the door as it opens to adjust the down force.
Step 3-Adjust the Safety Reverse
Use a piece of wood to stop and reverse the door, if the door doesn't reverse increase the down limit with a clockwise, one quarter turn.
Posted on Jun 16, 2011
Where is the best place to buy a battry charger at a reasonable prise?
Cheapest.....Rural King or Harbor Freight. Better quality at Wal-Mart or Sears. don-ohio (:^)
Jan 05, 2017 | Drills
Battery and or charger won't work. Charged a full 18 hrs. Help
Possible suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
Nov 27, 2015 | Motorcycles
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
Can i charge peg perego battery 12 volt with the regular car charger
Actually I did it successfully over the weekend with a Sears 6/2 amp car charger. First I removed the battery caps and topped the cells off with water. Then I set the charger on 6 amp for approx. 4 hours. I monitored it and as water began to overflow I suctioned it off. The result - a very happy grandson riding his Gator
Mar 13, 2012 | Peg Perego 12 Volt Rechargeable Battery
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
Battery in Jeep Grand Cherokee dead this am and less than 1 year old. I have a Everstart 100 battery charger plugged in and on the car. How long does it take to charge the battery. The charger is plugged...
How many amps does this charger put out????
A small trickle charger will take forever to fully recharge a dead battery, you'll need to have a battery charger that can put out enough amps to properly charge a dead battery.To clarify, the chargers sold at Sears, the large square types on wheels are the best for charging dead batteries and they also have an amp meter telling you how much the battery is accepting. After you charge your battery, you should be around 12.5 volts to 12.7 volts. DO NOT OVER CHARGE!!!
Jan 18, 2010 | 2004 Jeep Grand Cherokee
New black and decker rechargable mower.The chargers keeps going bad .I was charging it outside under a large covered patio.It was totally protected from the elements except heat and humidity.The...
would have the battery checked out and the little rectifier board see if its shorting out the chargers? also you cant leave thoses chargers on all the time i wolud suggest buying one from sears that cuts off when fully charged they sell them in the auto section just make sure you set it to the correct charging volts ? it should last forever cause it shuts down when charged
Aug 31, 2009 | Black & Decker 19" Electric Lawnhog...
DSealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
Yes you can charge the 12 volt bttery on a trickle charger. You should use a 1 amp or less charger. Check the battery every 1/2 hour or so for heat. If it get's hot you should stop charging. Power packs that have a 12 volt rating will charge your battery safer and better but will take longer (like a cell phone charger) look at the voltage ratings on the charger. You will have to adapt the plug to hook it up and test for correct pos. and negative connections. The 7amp hour batery should be fully charged by a .5 amp (500ma) charger in about 14 hours (multiply the amps times hours of charge and do not go over the 7amp hours of the battery when deciding how long to charge). After charging check voltage, it should be around 12. Let the battery set for a few hours (overnight) and check the voltage again. It should be around 12 still. A fresh charge will usually show a higher reading (called a surface charge) than a battery sitting around. 4.5 v will not operate your device, 9.5 v or higher should.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
59 people viewed this question
Top Craftsman Building Materials Experts
hpgwva
L Pfaff
L Pfaff
richie46
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
