Question about Bosch Canister Compact Plus Vacuum - BSA2100 Vacuum
Trying to fix (myself) the retractable cord. It would be great to have a schmatic of this machine
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
How do I fix the retractable cord on a Dyson DC19 vaccum cleaner
Great Youtube video
https://www.youtube.com/watch?v=4p0N2XwiKaw
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Aug 22, 2014 | Dyson Vacuums
Retractable cord
You did not identify the handheld sealer so it is impossible to prescribe a cure.
Jan 09, 2014 | Vacuums
Repair retractable cord
Depending on which model of Electrolux you have and how far out you have pulled out the cord (most of the Electrolux canisters have a yellow tape around the machine end of the cord to alert you not to pull it out any further), you might have to take it apart to fix it. However, the first thing that I would try would be to stand it on the end (the hose end at the top), and pull short jerks on the cord to see if it will correct itself and retract. If that does not fix it, I would stick a screwdriver in the hole where the cord comes out of the machine and attempt to wind the cord reel back up which will slowly wind the cord back up on the cordwinder. This usually cause the cord to wind back up. If that does not work, then the only option is to take the machine apart to fix it.
Dec 11, 2013 | Electrolux Vacuums
I have a Hoover Legacy model S3592 and the cord will not retract, it is fully extended. How can I fix this problem? Patty Lester
You may have to dis-assemble the machine to the point where you can gain access to the mechanism that retracts the cord. Then see if it can be fixed or needs replacement. Just don't lose any parts when dis-assembly, and make sure everything is put back together correctly.
Oct 14, 2013 | Hoover Elite & Legacy Vacuum Cleaner Belt...
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
Electric cord will not retract
I found the solution from another web site. Removed the reel coil, cleaned it of lint, etc. replaced it and it is now working. Thank you for your relpy
Jun 26, 2008 | Vacuums
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Sebo K 3 Vacuum
I had a problem with my K1 Komfort model which sounds similar to this. I initially thought the cord was too short but the machine wouldn't give out anymore and retracting was difficult. A Sebo engineer/helpline told me to pull roughly on the cord, of which I did and was rewarded with 2 metres more than what I thought I didnt have! So, perhaps if your machine isn't retracting properly, give the cord a rough pull with gloves on, or a strong grip - the cables on the K series are notorious for stopping up. Afterwards wipe the entire cord down with furniture polish; it will retract much more quickly.
Feb 21, 2007 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Bosch Canister Compact Plus Vacuum - BSA2100 Vacuum Logo
76 people viewed this question
Top Bosch Vacuums Experts
Billy Detlefsen
ray gallant
JoeVacs
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
