Question about Craftsman Garden
Only hums for abpout 10 seconds and then kicks off
There is a slight hum near the compressor that runs for approx. 10 seconds after which it shuts down
    Sergeant:
  • 458 Answers
Sounds like somethin has bound up the fan causing the automatic circut breaker to open. Open up the fan housing and clean it out.
Posted on May 19, 2014
Air conditioner and fan will not come on ,when set a hum is heard for 15-20 seconds then shuts down
Sounds like a bad run capacitor on the outdoor fan motor. Compressor kicks on but quickly overheats because fan is not running. Good Luck!!
May 12, 2017 | Heating & Cooling
My GDM-12 is not cooling. when I turn the temp up it make a loud humming sound.
If the humming last 3-5 seconds then makes a faint click sound and stops humming for a minute or two. Then resumes the hum again it may be your compressor locked down. Stuck. Most likely it is just a bad start capacitor not kick starting the compressor. A $6 part.
Mar 07, 2014 | True GDM-12 Refrigerator Commercial
Humming Noise
Fuel pump shuts off with key. Do you have air suspension? Could be the compressor for air ride but don't know what kind of vehicle you have
Nov 20, 2013 | Cars & Trucks
Running or not central a/c
There is a capacitor in the fan wiring that gives it a kick start. Replace it
May 20, 2012 | Heating & Cooling
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
Freezer compartment no longer cools. Continuous defrost cycle?
Good day,
Sounds more like the compressor trying to start and can't.
Pull the machine out, remove the rear cover and see if in fact the sound is coming from the compressor.
Apr 08, 2010 | Whirlpool Refrigerators
WMSD2756GES Clicking, slight burnt smell, humming then repeats
Replace the overload relays down at the compressor. Easy repair and too expensive. Do this and you'll be good to go.
Feb 01, 2010 | Maytag MSD2756GES Side by Side...
Refrigerator starts -runs for two weeks, compressor won't restart
It might be but I would first check the condenser to see if it's blocked or if the condenser fan (if it has one) is not working. The "buzzing/humming/ticking" sounds you're hearing is the compressor trying to restart after it became locked down. Excessive pressures in the system or compressor overheating is usually the cause although sometimes the bearings in the compressor simply lock up.
Check to see if the fridge cycles on and off by the thermostat. If it doesn't cycle and just keeps running then the thermostat is bad and that can cause compressor failure thanks to "slugging". If it does then you want to check the defrost timer. Turn the timer's dial until it clicks into defrost and see if it comes out on its own. Check if the compressor has trouble starting after defrost. If it stays in defrost the timer is shot. If the timer times out and the compressor will not restart then the relay might be bad or, the compressor might be going bad.
A 3in1 relay/capacitor/overload might help out and give the unit a little longer time but sooner or later it will go.
Jul 08, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Have Duo Therm roof mount A/C. Fan runs but when compressor tries to come on it just has a hum sound for about 10 seconds then after a short period of time it tries again but will not kick on
It sounds like the compressor is locked up. You can try a start boost or hard start kit but once this starts the compressor is on it's way out.
Feb 25, 2009 | Dometic Rooftop RV Air Conditioner
My new Amana compressor Central Air-Heat Pump hums very loudly
When it hums, is it running? Or does it not run when it hums? I'm assuming it runs when you say you have to turn the therm off to get the noise off.. If it's humming and not running, you have big problemo friend..
Dec 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Garden Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
