Question about Vehicle Parts & Accessories
Sawybar mount replace subframe drop
Lower subframe procedure
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
You need to support the engine from above. A tool is made for this but you can use a 4x4 piece of wood and chains. When the engine is secure you then need to have the vehicle raised. You didn't say what vehicle you have so this is general. Lower ball joints need to be separated from the knuckle and 4 to 6 bolts hold the sub frame. Spray paint around the bolts to mark their location, this will get you close for alignment. There will be other bolts for trans mounts etc.
Posted on Apr 19, 2014
Check eng light on a 1998 buick century coad p7053 12 shift solenoid . IS IT EXT PART OR INT PART , HOW EASY IS THE REPAIR?
The shift solenoids are mounted to the valve body which is behind the side cover of the transmission. Usually you have to lower the trans to remove the side cover, which envolves lowering the subframe. If you drop the subframe the steering rack must be disconnected and the engine must be held from above because most of the motor/trans mounts are on the subframe
Aug 31, 2011 | 1998 Buick Century
Hi i need to change motor mounts on my 2005 pacifica never dont it before too espensive in the shop can you tell me how dificul it is thsnk you
you have to lift the engine out of the vehicle far enough to remove bolts this can be a complicated process
Apr 27, 2011 | 2005 Chrysler Pacifica
What is a sub frame on a auto
The Subframe is a metal frame like enclosure that surrounds the Engine /Transmission. The Engine/ Trans drops into the Subframe and in turn is bolted to it via Engine Mounts and the Subframe is in turn bolted to the uni-body of your car via Subframe Mounts.
Feb 05, 2011 | 1997 Pontiac Sunfire
Are there any other parts that need to be removed in order to change the front engine mount of a 2005 chrysler pacifica?
are there any other parts i need to move, in replacing front motor mounts for 2005 pacifica
Nov 05, 2010 | 2005 Chrysler Pacifica
How do i install a new swaybar on a 2000 buick century . can i take wheels off and put swaybar through ther?
Removal & Installation Because the front stabilizer shaft is mounted to the powertrain subframe, the subframe (with the powertrain) must be lowered to service the stabilizer bar. This is a lengthy and exacting procedure requiring special lifting and jacking equipment. In addition, the rack and pinion steering assembly stub shaft must be disconnected from the steering column. GM specifies that the subframe-to-body bolts, once disturbed, must be replaced with new service replacement parts. Procure the necessary hardware before beginning this procedure. This is not a job for the inexperienced or ill-equipped.
May 28, 2010 | 2000 Buick Century
Can I change the shift solenoid 1-2 (code P0753) 1997 Buick Century. Where is it located?
The shift solinoids are mounted to the valve body which is behind the side cover of the transmission. Usually you have to lower the trans to remove the side cover, which envolves lowering the subframe. If you drop the subframe the steering rack must be disconnected and the engine must be held from above because most of the motor/trans mounts are on the subframe
Jan 10, 2010 | 1997 Buick Century
How do i remove the transmission in my 95 geo prizm
This requires a boom which is a mounting brace which that holds the engine in place (from the top) as you drop the lower subframe in order to remove the transmission. Once the boom is in place and hooked to the engine,lift and remove wheels,exhaust,lower control arm,axles,subframe and finally the transmission. .
Aug 23, 2009 | 1995 Geo Prizm
Steering Rack boot replacement
In my opinion, removing the front subframe makes this job much easier.
Jack up and suitably support the front of the car so it is in a wheels free state.
With wheels removed;
  • Remove the anti-roll bar drop links from the anti-roll bar
  • Free off the lower arm ball joints off
  • Remove the track rod ends from the swivel hubs
  • Remove the nut and bolt and special clip on the lower steering column universal joint
  • loosen off and disconnect the feed and return pipes to the power ram (beware stinking power steering fluid pouring everywhere!)
Steering and suspension wise, the subframe should be free!
  • Remove the nut and bolt that secures the lower engine mounting to its bracket (the bolt that goes through the big round rubber mount at the back of the engine)
  • Disconnect all relevant gear linkage rods (this will be clear when you are under there!)
  • Support the subframe with a jack or somesuch and free off the 6, 18mm bolts that secure the subframe to the body shell.
  • remove all subframe mounting bolts.
  • lower the jack that is supporting the subframe, it should all drop quite nicely and then get stuck on the steering column universal joint! A good old college shove frees this and then you should be able to remove your subframe assembly from under the car.
Jul 30, 2009 | 1997 Mitsubishi Diamante
How do i change the subframe bushes on my jaguar xj6
I am assuming you mean the rear ones! you neeed to jack up and support the car, as you will be moving the rear subframe support the car on the forward end of the large arms that go to the floor (it is allways solid there) depending on the make and condition of the exhaust you might get away without disconnecting too much of it. support the subframe centrally with a jack, unbolt the 4 nuts and bolts that hold the mount to the subframe, lower the subframe enough to unbolt and change the rubber mounts, if the exhaust or brake flexy stop it dropping enough to change the mounts disconnect them, refit and tighten.
May 18, 2009 | 1994 Jaguar XJ6
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
