I have a Proscan tv (model 26LB30QD) and I connected the WII to it. Currently there is no sound or the little hand/mouse that allows you to click on main menu items such as Netflex. Can you help?
I have hooked up the Wii to the TV and now I can not get sound or mouse/little hand to make selection on main menu for Netflex. can you help me?
SOURCE: Screen splits into 2 vertical images when connecting Wii Component
if you have a user manual find the word settings, then look for the word NTSC/PAL. mybe you can change your mode which is compatible to your TV set. one more suggestion, set your Tv set in auto mode in Video.
Posted on Apr 11, 2008
SOURCE: I can't select TV/Video input on the menu
Prueba poniendo canal 00 en el tv varios modelos de rca entran en modo de auxiliar en este canal.
Posted on Mar 12, 2008
bhiga
  • 119 Answers
SOURCE: polaroid tv Wii connection
Your LCD TV should have one of the following types of inputs:
  1. Composite. This is usually a yellow jack, along with red and white jacks for audio.
    If your TV has these, which it should, then the cable that comes with the Wii will plug directly into these jacks. Plug the yellow to the yellow jack, the red to the red jack, and the white to the white jack.
  2. S-Video. This is a flat black jack. There are four little holes, and one "flat" rectagular hole. There should also be a red and white jack that go along with this for audio.
    In order to connect to this input, you will need to purchase an S-Video output cable for the Wii. Most stores that sell Wiis will sell a third-party cable for this.
    This connection will give you a significantly better picture than Composite.
    S-Video does not carry audio, so you still need to plug the red plug into the red jack and the white plug into the white jack or you'll get only video and no audio!
  3. Component video. This is a triplet of Red, Green and Blue jacks. There is usually a set of red and white jacks along with them for audio again.
    This connection will give you the best picture, and you can set your Wii to EDTV (Progressive) mode.
    To connect to this input, you will need to get the Wii Component Video cable. Most stores that sell Wiis will either sell the official Nintendo one, or a third-party cable.
    Connect the red plug to the red jack, the green plug to the green jack, and the blue plug to the blue jack. Also connect the red audio plug to the red audio jack and the white audio plug to the white audio jack.
    Be careful not to get the red audio plug confused with the red video plug!
    If you see a picture, but the colors are wrong, then you either swapped the red and blue, or you connected the red audio plug instead of the red video plug.
Posted on Apr 05, 2008
Superkris
  • 9 Answers
SOURCE: Hand icon wont appear on the Wii main menu
Well, mabey your sensor bar settings are out of wack. You might have your sensor bar set to above TV but you actualy have it below. To fix it, I would move the sensor bar to the opposite position, go into settings and chanage the sensor bar settings to the way you want. then put the sensor bar back where you want it.
Posted on Dec 24, 2008
SOURCE: set up Sony Wega TV on Video 2 for a Wii system
In the set up screen: Video reset ports and activated them individually to allow the TV to recognize the game and the DVD players...
Posted on Dec 28, 2008
Audio Output
menu select audio out put option & find socket R-out, L-out.
May 30, 2012 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan Model 26LB30QD purchased at bjs will not turn on. makes a noise which sounds like the dvd player then powers down.
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
May 27, 2011 | Proscan 32LA30Q Television
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
Feb 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Remote for tv
If your TV model number is 26LB30QD, it's $32.12 at remotes.com
Rate me if I answered correctly
Feb 02, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Nov 22, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
