Question about GE Profile PSS26NGS Side by Side Refrigerator
Ice door flap will not close
The ice dispenser flap is supposed to close when ice isn't being dispensed. Instead it stays open and moisture enters the freezer compartment.
  • 4 Answers
I had a similar problem once. i opened the door and used a hair dryer blowing into the dispensing area of the door. There was a ice build up that was not visible with a quick look. It takes a while so be patient when thawing and be sure not to use too high of setting so you dont deform any of the plastic parts.
Posted on Apr 15, 2014
5 Suggested Answers
aasc
  • 1606 Answers
SOURCE: ice dispenser door flap will not close.
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Posted on Sep 02, 2009
aasc
  • 1606 Answers
SOURCE: The ice dispenser door stays open. Selenoid works
This is due to a rusted solenoid plunger .You will need to remove the top freezer door hinge cover ( 1 screw ) , and disconnect the plug there . This will remove power to the dispensor . Using a screwdriver , insert it just behind the dispensor board , and twist , to pry the board off . Remove the 3 plugs there , and remove the board . Remove the 4 screws on the white cover , and slide the cover out and off . In the top right , in the dispensor area , you will see the solenoid and plunger . 3 screws hold the solenoid on . Lift the flap , and the plunger will lift off . Part number for solenoid and plunger is WR62X10055 . The closing spring is probably good , and if you are pushing the flap closed , you are moving the plunger itself , instead of it gliding inside the solenoid , to the closed position .
Posted on Nov 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: The flap on the freezer door for ice dispenser does not close
I will need that model number listed on the fresh food section behind the door and near floor kick plate, let me know if you have trouble finding the model number. Sometimes it is hard to find as every company puts theirs somewhere different, Thanks, Sea Breeze
Posted on Jun 11, 2009
kapishtech
  • 2272 Answers
SOURCE: Re: GE ZISB420DMC Refr Ice dispenser
It’s the flap, the spring, the crank, or the solenoid (the device that opens the flap). Now you need to remove the front cover off the dispenser (on most refrigerators it just snaps off). Then remove four screws behind the cover and remove the dispenser control. Once off you should see the flap. Inspect the spring to see if it is broke or out of place, if so, replace it. Then see if the crank (the part that the flap is attached to) is broke, if so, replace it. Now look at the flap to see if the edges are rolled over or is broken, if so, replace it.
Now for the solenoid, sometimes it gets rusty and won’t close all the way. Sometimes it overheats and welds itself open, if this happens it won’t open or close. In any case, if it doesn’t open or close properly replace it.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 13, 2010
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Freezer door ice dispenser flap will not close completely. The cold air is leaking out of the freezer. What can I do to fix?
There are multiple parts to the dispenser for GE. You say that door isn't closing properly, which could mean that the solenoid isn't working properly, or that the door flap retainer itself is broken, I want to say that they make a complete kit for it but not for certain,
Jun 02, 2012 | GE Refrigerators
Ice will not dispence thru door.
Without knowing the brand and model # I can offer the most common solution.
On most "pass the ice through the door" models there is a flapper door where the ice dispenses. The spring which holds this door closed when you are not dispensing ice becomes weak allowing the flap to stay open jsut a bit. This open space will create an ice dam in teh dispenser thus not allowing the ice to dispense. The repair is generally made by replacing the flap assembly.
All the best.
Nov 21, 2010 | Refrigerators
Nov 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Ice dispenser flap won't close automatically
replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
GE Profile PSS26NGS Side by Side Refrigerator Logo
191 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
