Question about Cuisinart ICE-20 Automatic Frozen Yogurt 1.5 Quart Ice Cream Maker
Ice cream boy not spinning
The shaft no longer rotates. The chiller works fine.
Is there a trick to removing the shaft that turns the beater on a Taylor ice cream machine? I often have trouble removing one or the other shafts when cleaning the machine.
Most likely your alignment is off on the gear box that has the coupling attached to it, you can try to lift the box up alittle after loosening the bolts and just tighten one and recheck until it pulls out freely with no effort
Jul 25, 2011 | Taylor 632-27 Ice Cream Maker
Does the dasher move on the ice cream maker or just the canister?
The dasher rotates, driven by the motor. The canister isn't supposed to move, but sometimes will depending on how thick the ice cream mixture gets. Presumably, if the ice cream were to freeze hard enough, the dasher would find it harder and harder to turn, until eventually the entire canister, with the dasher embedded in the ice cream, would start to rotate in the ice.
Mar 04, 2011 | Nostalgia Electrics ICMP-400BLUE Ice Cream...
I have an old Simac Il Gelataio Super. I believe the clutch is broken. It will only churn until the product is very soft. Then the blade stps because the drag on the sides is too great. Is this...
It sounds like the main gear is cracked were the paddle shaft goes though it.the d shaped shaft is spinning when the ice cream gets firm. i repaired mine by making a sleeve out of copper pipe and slid it over the cracked part. works great.
Dec 11, 2010 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Ice cream freezer purchased last year and used twice will not run, seems to be froze up
Could have got salt and water in the top of the motor which siezed the motor shaft. If it humms try taking it apart and spray some WD40 on the motor shaft and other shafts
Make sure it is unpluged first!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Aug 09, 2009 | Hamilton Beach 68330 4 Quart Ice Cream...
Not setting / freezing - bowl in freezer 24 hours *
The ice cream mix has to be xconstantly stir in a nrine solution, That's why they have motorized ice cream makers that rotate the can surrounded by ice and salt.(brine) while a paddle inside stirs it. Good luck and enjoy.
Jun 01, 2009 | Disney Ice Cream Maker
Put the ice cream bowl in the dishwasher
The only way to tell is by putting it in the freezer for 24 hours, and then trying to make a batch of ice cream. If it doesn't freeze or make the ice cream properly, then you will need to get a replacement bowl from Cuisinart - they are available.
-Tha Mp3 Doctor
Aug 11, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
When the paddle on my machine has stopped rotating it shoots the motor and guard off the top
you are letting the ice cream get to frozen, this should be a soft gelato ice cream, after 20 minutes turn off the top motor a leave on with the freezer unit still working or take out mixture put in tubs and put in freezer, the lid is designed to come off to stop the machine from breaking. Any magimix parts can be bought at http://www.magimix-spares.co.uk/
Feb 20, 2008 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Ice cream has ice crystals in it
Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
Here are some of the useful tips:
1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
Hopefully this information helps a lot.
Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
After a hour and half we still do not have ice cream
You need to make sure you continually refresh the ice as it melts, you also need to make sure you put salt on the ice. The salt makes the ice colder so that the ice cream can freeze up better.
May 29, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
Cuisinart ICE-20 Automatic Frozen Yogurt 1.5 Quart Ice Cream Maker Logo
37 people viewed this question
Top Cuisinart Ice Cream Makers Experts
Greg Cann
Greg Cann
Jay Finke
Jay Finke
solver2010
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
