Compaq Presario CQ62-215DX Laptop Logo
Lisa Crouch Posted on Mar 17, 2014
Black screen cap lock blinking - Compaq Presario CQ62-215DX Laptop
My HP DV3 screen is black with caps lock and scroll lights flashing, what do I do?
Those are POST error blink codes
covered in the manual (service)
at HP.com
DV3 is not a complete model , it is just a series.
example real
Dv3-1075us 2008 ,,made. 14 years old ,
common fails are coin cell dead, now 2x normal life span.
HDD bad., now cant boot.
remove huge battery and run on AC power pack, does that work.
oops big battery bad too.
CCLF lamps make backlights dead. most are now. dead screen.
windows VISTA loaded.
HP ended support, sad no? and here is a guy that saved the secret codes (caps lock POST error blink codes)
https://topvinylcutters.com/hp-caps-lock-blink-codes/
The question on the hp g42 the f12 lightOrangestay's on And the cap key blinks 1 x every 3 sec.
could be faulty ram or screen faulty,or even over heating,clean out the fan.
Hp g56-125n notebook caps lock blinks continuously blinks and black screen
When caps lock blinks it means the computer is either having a problem or DESPERATELY needs to tell you something (like when you run diagnostics and encounter a error). Hope this helps!
I have an hp G42 notebook when i hit the power button i hear it turn on but nothing happens only the caps lock key light begins to blink
hp blink error code:
caps lock blink once: cpu error
caps lock blink twice: bios problem
etc,,,,
please, what is the numer of the blink ?
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
4helpful
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
DO RATE MY SOLUTION
6helpful
2answers
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
3helpful
2answers
Inspiron 1501 startup problem
hi,
-this is a possible problem in the memory of the computer
-if you are familiar in opening the computer and removing and returning back the memory please reseat the memory; if not contact your manufacturer for possible memory replacement
cheers!
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
