I have the infinity rs8a tower speakers and they sound good but when I turn the volume up the subs turn on and off on both towers
  • 3,320 Answers
When sub-woofers are overdriven (played too loud) they create a lot of heat. You can try using an external fan or improve the ventilation around the speakers. Most good speakers have thermal cut offs that prevent permanent damage.
Posted on Mar 20, 2014
  • Jason Mar 27, 2014
    When I turn the volume up at all they can barely be playing and the amps turn on and off till I lower the volume I have all bass turned down and it still does it
sanjin
  • 56 Answers
SOURCE: Speakers sound quiet and unclear
You probably burned tweeters and damage midranges but before disasembly check equalizer
Posted on Feb 29, 2008
brainyass
  • 242 Answers
SOURCE: i have some old home stereo towers
You only need the impedance of the speakers, power rms, and mounting hole size. Go here and mix and match their huge selection.
http://www.parts-express.com/speakers.cfm
Posted on Nov 21, 2008
  • 336 Answers
SOURCE: I need the ambulical connection from the left
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&modelNum=SAVA1&searchText=SAVA1
1-800-488-SONY (7669)
Link to Sony web page for SA-VA1 and Phone # for Sony part orders
Posted on Nov 11, 2009
  • 5 Answers
SOURCE: My S606 developed a problem whilst playing. Sound
Try doing an auto-calibration through your amp to check that all the speakers are correctly connected, if they are then try play around with the EQ. otherwise, chances are it's a manufacturing fault
Posted on Jan 11, 2010
Grubhead
  • 5390 Answers
SOURCE: My Infinity sub-woofer for my home surround sound
Open it up and see what is in there! You might find a fuse blown. It might have just blown, without a fault, if you are lucky. If not check out the part numbers on the amp board. All semiconductors numbers, then put the numbers into google. You will soon find out if they are obtainable!
Posted on Jan 20, 2010
How to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
May 02, 2012 | ASUS Computers & Internet
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
No sound from this monitor. I have everything plugged in , volume icon is turned all the way, mute is off, adjusted speaker levels, etc on my desktop.
Firstly,
You need to check if the green cable from the computer tower is blugged into the back of the monitor (The cable looks the same at both the ends) this is for the output to come through the monitor.
If that is plugged in and if not working, Try a headphone on the tower and check if the sound is coming from the headphone, If yes, You will have to adjust the volume on the monitor or the speaker of the monitor might have gone bad. If there is no sound coming in, Then the problem is with the tower and not the monitor.
Dec 02, 2010 | Acer X193W LCD Monitor
Convert Infinity RS2 (old towers) to bi amp
Dont do it they are not designed for this.
Jul 17, 2010 | Audio Players & Recorders
Only the sub anbd one of the four tower speakers
The center one, right? You need to plug in all 3 plugs in the sound card, otherwise they won't work.
Feb 16, 2010 | Dell 5650 Computer Speakers
My Emachine is only 2-3 yr's old now & I have never had sound. It was the cheapest one & on sale. I must have chose one that did not have a sound board. I can not put in a sound board by myself...
Are you sure there is no onbaord sound it should look like microphone or headphone socket holes. If it does then you are needing the correct driver. Open the tower and check what motherboard you ahve then post again for the correct driver.
If there is no sound onboard then it is very simple to install a pci soundcard anf they are very cheap. I certainly wouldn't go buying a new tower for just sound. Google on installing a pci card and you will see how easy it actually is or ask a young friend they know heaps about computers.
Oct 05, 2009 | E-Machines eMachines Desktop PC
I own infinity tower speakers ...the rubber around
time to replace the speakers. you can buy just the speakers to go into those towers. look on infinity's website for them.
Jun 12, 2009 | Car Audio & Video
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
Where can I purchase...
Jason
I think is better to get your equipment, to repair shop and see to fix the input for the sound, it is better, or buy a new board, it is cheap, you may found, on 140.00 less ASUS or SOYO brands,
good luck
Jan 17, 2008 | Logitech Z-560 Computer Speakers
Crazy cycling noise
a quick test, change the speaker wires between the speakers, if the sound goes over to the other speaker the problem is in the amp. But if the problem stays with the same speaker tower the problem will be in one of the speakers in the tower. since you said you get no sub sound I suspect ithe problem is not the amp, but the sub speaker itself
Oct 26, 2006 | Polk Audio RT1000I Speaker
64 people viewed this question
 Grubhead
Grubhead
