Question about Irulu iulu 10.1 inch Andoid 4.0 Touchcreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL
Low volume, seems volume button is wired backwards. push on the left side and volume raises
    Scholar:
    New Friend:
  • 61 Answers
My Android (not an Iolo) has both a touchscreen volume control--as well as a pair of physical volume control sliders--the latter on the right outside edge. I put the tab into a temp car mount: The resulting friction slid the volume down to nil--the the physical sliders, contacting the mount, proved the culprit (despite the touchscreen volume control setting). I proved puzzled at first, cursing the tab.
Posted on Mar 19, 2014
IPad volume too low
increase the volume by pressing the volume up button key at side of your tab or go to
settings
sounds
Mar 19, 2018 | Tablets & eReaders
Will not factory reset using power button + volume up button. What do I do?
some devices need you to press power button + both volume up and down.
Apr 19, 2015 | Tablets & eReaders
How to restart my tablet without turning it on because I forgot my password?
Look in your tablet instruction book for a procedure called 'hard reset' or a location for a small hole on the edge or back of the tablet where you can push in something non-conductive, like a toothpick to press a hidden reset switch. Without having a make and model for your tablet, it is hard to determine what exactly to do because each make and model is different. You talk about pressing the power and low volume buttons- are you holding them both in simultaneously for 10 seconds? This might be the reset procedure for your tablet, but that is not clear. One last thing to try is to hold in the power button for 10 seconds and see if you get a power off screen. If you get this, try powering off the tablet and then restarting. Also make sure the keyboard isn't on caps lock when you type your password.
Jan 03, 2015 | Tagital Taital TM 7" Android 4.0 4B MID...
How to reset tablet
Try this: Switch OFF the tablet. Now, push and hold VOLUME UP. Push POWER button. Will start with a menu. Keep holding VOLUME UP until that menu appear. After this, use VOLUME UP and DOWN to navigate in menu.Choose factory reset. Be adviced, that will be delete al of your data.
Alternately, use RESET SWITCH on the back side.
Aug 18, 2014 | AGPtek TP714AQ-A 4 GB Tablet - 7" -...
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Jul 12, 2014 | Proscan 7-Inch Android Internet Tablet,...
Forgot password
  • Turn off the unit.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Nov 15, 2013 | Coby Kyros 716829701508 Tablet PC
I have locked myself out of my tablet
You will need to do a factory reset:
Oct 29, 2013 | Proscan Recertified - PLT7035 4GB NAND...
How Do I Get Past a Pattern Lock MID8024
  • Plug the unit into an electrical outlet.
Aug 23, 2012 | Coby Kyros MID80244G Tablet
Wont start up the screen only displays the android logo i've tried pressing the reset button many times but still the same
Try a master reset:
Oct 08, 2011 | Coby Kyros 7" Touchscreen Tablet
I want to change owners so I want to reset Kyros 8024. How do I do that?
Following the instructions below will cause losing all user data, including the third party installed applications.
This action will even delete the "Getting started" video file, which will cause the "Cannot find video" error when a user is trying to play the video clip using the "Getting started" application. With knowing this fact, the user can follow the instructions below.
Jul 20, 2011 | Coby Kyros 716829701508 Tablet PC
Irulu iulu 10.1 inch Andoid 4.0 Touchcreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL Logo
106 people viewed this question
Top Irulu Tablets & eReaders Experts
john smith
gbob59
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
