Question about All-Clad (HCOF8H2MZQ) 65Quart Slow Cooker
Do you have to turn off slow cooker to change heat and time
I want to change from high to low temp on the cooker, do I have to turn it off first?
    Champion:
  • 287 Answers
No. You should be able to reset the temp as needed.
Posted on May 08, 2014
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
After the slow cooker boils is it better to turn it down to low
it is a slow cooker for the purpose of slow cooking so turn it to low and it will keep cooking
If you want fast cooking on high temp use a pot or a pan .it will be cheaper.
Apr 18, 2015 | Crock Pots & Slow Cookers
My rival crock pot model 5865 sticker on the heating unit that tells you high/low etc. fell off and now I don't know which position is high or low? Can you help? Can I buy a replacement sticker? H
L to R Round Left Button- Low-High - Warm Two buttons over each other Top - time up, Bottom, Time down Most Right Button - OFF Lights Left - HIGH Center - KEEP WARM Right - LOW
Nov 09, 2012 | Rival 5865-W 6.5-Quart Slow Cooker
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
Whats the differences with the low high and auto settings on a slow cooker which setting is considered best for cooking stews
The difference is the time and how warm it cooks. Low cooks a slow, lower heat - cooks 6-8 hours. And High is a faster cook at 4-6 hours. I tend to use low for stews and chilis.
Feb 11, 2010 | Crock Pots & Slow Cookers
When you set the cook time it goes to warm will it change after it warms up
with this slow cooker it is automatic for temp settings you set the time and the rest is automatic, 1-6 ohurs starts on low and 7 and above start on high it worked out great
Nov 06, 2009 | CorningWare K4903 Slow Cooker
Ronson slow cooker don't know which is high or low
on setting 1 (low),the slow cooker can operate all day and night if required
when set to 2 (high) it is very much like a covered pot on the stove.food will cook in half the required time
AUTO the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature,then switches to 1(low) and maintains a constant slow cooking temperature.Auto is ideal for someone who is leaving the house for the day 8-9 hours please feel free to share this information.If you have any more ? please fell free to contact me.
bianca
Jun 12, 2009 | Crock Pots & Slow Cookers
Need directions for presidents choice slow cooker
Heat intensity is warm, 1, 2, 3 (highest)
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
Apr 11, 2009 | Crock Pots & Slow Cookers
Slow cooker not hot
If you only have High and Low on the slow cooker this will be normal until it reaches correct temp, the trick is Do not remove the lid once you have started the process, you lose 20 minutes cooking time every time you lift the lid during cooking, if you have timed ex,4,6,or8 hours just set to required cooking time and leave until done. hope this helps clarabella
May 18, 2008 | Crock Pots & Slow Cookers
We are having difficulty timing our slow cooker recipes in the KC271LC .
The manual doesn't say what the levels are, but the cover says the AC power rating is 340 watts. Most of that would be going to the heater, and low temp should be about half that. If you need a copy of the manual, here's the download link:
http://www.euro-pro.com/europro/manuals/KC271LC.pdf
Oct 31, 2007 | Euro-Pro KC271LC Slow Cooker
All-Clad (HCOF8H2MZQ) 65Quart Slow Cooker Logo
119 people viewed this question
Top All-Clad Crock Pots & Slow Cookers Experts
Irene Tulloch
Tom Chichester
Bill Boyd
Are you an All-Clad Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
