Question about Avantco Equipment Avantco W50 12" x 20" Electric Countertop Food Warmer
Want heat need to order part ksd301 16 amp 250 volts 110 Celsius. where do I find it and how much does it cost?
How many Horse power Dei-815/E freezer
Freezers are not measured in horsepower, only mechanical engines. This is the specs, and it is basically a 25 amp freezer, with an additional 7 amps or fans lighting and door heater, both at 250 volts AC. However, running an Amps to HP converter gives 6.971 horsepower.
DEI-815 dual controller with external probe box d
  • DEI-815 dual controller boxed With external probe
    Set Temperature range: -40 to +40
    Tolerance of 1 ° C
    Contact compressor outlet 25 Amp. 250 VAC
    25 Amp Output contact resistances. 250 VAC
    Contact Fans, lighting and perimeter heater 7 Amp. 250 VAC.
    Connection 110- 220 V 50/60 Hz.
    NTC sensors 02 1.5 mt.
Mar 16, 2016 | Cars & Trucks
I want to buy a festoon light (10 lamps) to light my attic. It is advertised as 110V is it safe to pkug it in to my socket (UK)?
In esence the answer to the question is yes, but you need to take a few things into account.
Obviously, you are going to have to put a UK socket and 220v bulbs into the unit, but the main issue you need to be aware of is the capacity of the wiring in the unit to take the load in the UK. What you want to know is how many amps it used to draw when it was 110v and how many amps it will draw now. Clearly, a UK 13 amp plug will be man enough for almost any light unit (with the correct fuse fitted) but you would do well to ensure that you don't exceed the original planned load for the current, because the WIRING in the unit is the weakest link.
Working it out is fairly easy: Watts/Volts = Amps
So: When it was 110 volts, it maybe had 10x25 watt bulbs in it.
10 25 watt bulbs is 250 watts
250 watts divided by 110 volts means it was drawing about 2.3 amps, so set your limit as 2.3 amps load on the UK curcuit to ensure that the unti wiring can handle the load.
The easy way to fugure this when swapping lights from 110v to 220v is that if it was 110v, then you can use up to double the wattage on a 220v curcuit (and consequently, if you're going from 220 volt to 110 volt, then half the wattage.
Ensure that you use the Watts/Volts=Amps to calculate the correct fuse rating for the item
Sep 09, 2011 | Kitchen Ranges
Given 1hp motor how to compute the exact amount of amphere use in circuit breaker
You're not going to be able to do this with just a known Horse Power.
There are 3 elements to the equation, with any two, you can work out the third.
If you want to know how the amperage, you will need to know the voltage and wattage of the motor. I imagine that you already know the voltage (It's going to be 220V or 110 volt)
Watts divided by volts = Amps
Examples:
A 220v 1000 watt motor (1000 divided by 220) will draw 4.55 amps
A 110v 800 watt motor (800 divided by 110) will draw 7.27 amps
Bear in mind that most washing machines have a couple of windings for wash and spin. As an average, the was winding will usually be about 500 watts to spin and about 250 watts to wash. ALSO, bear in mind that if you are using this data for a WASHING MACHINE, then there is a water heating element in there too and that draws about 2Kw (2000 watts)
Dont just take this as read, you DO need to check wattages, but, working on what I have just said, the max consumption on a 220V machine will look like this:
At Spin, with a 500 Watt consumption: (500/220) = 2.3 amps
While Washing with a 250 watt consumption: (250/220) = 1.14 amps
Consider that the WASH and HEAT may be running at the same time.
2Kw heating (2000/220) = 9.1 amps PLUS 1.14 amps for the motor - Total wattage 10.24 amps
Watts / Volts = Amps
Amps x Volts = Watts
Watts divided by amps = Volts
Aug 25, 2011 | Washing Machines
My Bosch Dryer is not heating, we have cleaned all the lint from front and from hose in back of dryer, still no heat.
Check your voltage. Take a volt meter and make sure it is set on 250 or higher volts. All electric dryers needs to have 220 volts going to them. One 110 goes to the motor and one goes to the heating elements. If you are only getting 110 volts only one side then it is your electrical problem. Check your breaker or fuses.
Apr 30, 2011 | Bosch Nexxt 500 Dryer
It runs the battery down
Does your frig have 110, Gas and 12 volt setting? ... or is it auto select?
This is the way they should work ... if there is 110 Volts, it should run on 110 volts. The device is still controlled by 12 volts but the heat source is electric. If there is no 110 volts, it should switch to gas as a heat source. Same deal with the control, runs on 12 volts. If there is no electric and no gas, it should select 12 volts for a heat source ... same deal with the control. Problem with 12 volt source for heat is it GOBBLES up the power in your battery.
How is your battery? Do a volt test on the battery and the charger. Charger should run about 14 volts. Battery should provide at least 11 volts. If it is such that you can measure the acid, a good reading is 1200. Your charger can provide only about 15 amps charging power. Your battery should be able to provide up to 110 amp/hours.
If you do have electric and gas, it may not be your frig that is killing the battery ...
Thanks for your quesiton @ FixYa.com
Mar 21, 2011 | Dometic RM2852 Refrigerator
What amperage breaker required for neptune 5500 dryer? Also, it shows 120/240 volt on back canit be wired for 110 current? Thanks, Mark
No it can NOT be wired for 110 .Actually everything it the unit runs on 110 volts except for the heating element which needs 220 volts..As far as the circuit breaker is concerned you need a minimum of 30 amps
Nov 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Can ce 2000 be converted from 110 volts to 240 volts ? How much would it cost?
You could get an outside box called a Step down transformer that would deliver 110 volts to the amp. A quick look on Google should come up with prices.
All you need however is a new transformer. If you can find the specifications for the one in the amp it will be much easier to get a new one. All you need to know is the outputs of the secondary windings of your amp's transformer and current ratings. The primary winding will be 240 on the new one and 110 on the old. But you can get one with both!
If you ask Crown they might even convert it for you or put you in touch with someone who will.
Nov 18, 2010 | Crown CE2000 2-Channel Amplifier
Conversion from 110 volts to 220 volts
sorry the machine is made to work at 110 volts .so u cannot use it
Apr 10, 2010 | Saeco Royal Office Coffee Maker, Espresso...
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
Avantco Equipment Avantco W50 12" x 20" Electric Countertop Food Warmer Logo
446 people viewed this question
Top Avantco Equipment Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Avantco Equipment Kitchen Appliances - Other Expert? Answer questions, earn points and help others
