Question about Wolff Sunvision Pro 24S Tanning Bed
We moved my tanning bed from up stairs to down stair and now it won't turn on it will turn on when we hold in the contacts manually once we let go it shuts off
This happened to me also and I had to replace my timing board. Make sure that the blue jumper on the prong on the old timing board is on new timing board just like it is on old one and if not just take it off and put it on new timing board.
Posted on Mar 18, 2014
Testimonial: "I just notice it shows the wrong name for my bed my bed is a Dr Mullers Sun Storm 44/4 would this be the same problem the timer board and where would I buy a new one. How can I make sure it's the timer board thanks for any help"
  • Traci Adcock Mar 18, 2014
    I would recommend calling 770-505-4006 ext.109, which is Paul at Wolff tanning.com. They were very helpful and told me the problem, shipped the item and instructed me on how to install myself without having to pay anybody. Love this place. Tell him I sent you. Good luck.
  • Joan Woodward Mar 19, 2014
    Thanks so much Traci we bought the bed only a couple months ago from a salon and everything was working great just order new bulbs and decided to move it down stairs and now it won't turn on unless we do it manually. We will call first thing in the morning I will keep u updated
How do I fix a squeaky wooden stair step I recently installed.
Should never use construction adhesive on stairs as too dangerous. Proper way is to use wedges to remove squeaks. You could try a silicone spray like Jigaloo, or remove that step for a new one with a strip of rubber under it.
Don't you find the stairs incredibly noisy!
Apr 11, 2016 | Exercise & Fitness
Savaria stair lift
when we push the buttons to move it up or down it just makes the noise that it does when it starts to move but it does not go. Light on on the chair. Changed batteries in controller. HELP
Feb 02, 2014 | Medical
If floor to floor (height) is a 100" and stairs
no calculator on me but the answer is tan(100/134.5) because tangent = a/b and b is always the letter opposite of the angle
Jan 16, 2011 | Texas Instruments TI-84 Plus Calculator
My stair master the step keep moving could it be the brakes I have a stair master step mill and its used when I get on it the stairs moves is that normal also should I get a tune up on it and about how...
Yes it normal it on the same premise as using a stair stepper the mechanical movement engage the electronics letting it know HeY!! it to work out!!!
Jan 11, 2010 | Stairmaster Stepmill 7000 Pt
Miele Solaris won't turn on after falling down 1 stair.
there is no reset on this model. look @ your miele info & it shows you where it would be. I just had to look for mine when it would'nt start. mine ended up being cord winder kink affecting motor.
good luck
linda
Mar 15, 2009 | Miele S514 Solaris Bagged Canister Vacuum
I need to move my Proform XP 620 treadmill down a flight of stairs. What is the best way to do this
Honestly, the best way to do this is to call an expert because any wrong adjustments to a treadmill can cause serious damage but if you want to attempt yourself you must try to move it whole with 2 people stronger holding the front of the tread as this is going to be the heaviest. Take the front down first down the stairs.
www.AtlantaFitnessRepair.com
Jan 19, 2009 | Proform XP Weight Loss 620 Treadmill
How to secure front loading drum for moving????
transit bolts vary with machine. pack polystyrene blocks tighty between tub and cabinet and that will do the trick
Sep 25, 2008 | GE WCVH6260F Front Load Washer
Moving the TV
you should be fine as long as you don't drop it of course. you and turn and twist it any which way but id say measure the height of the tv because at some point you will have the top and bottom of the tv touching 2 different walls if im not mistaken
Feb 13, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Moving Information
Poczekaj, not a good idea to break it down, screen assembly is veery fragile when not installed into the set, best thing to do is rent a refridgerator type dolly, wrap the front of the set with blankets and then put the dolly under the side of the tv, winch up the strap and with 2 people walk it up the stairs, one pulling the dolly the other person at the other end to push upwards, slow and easy and you`ll have no problem, if hauling in a pick-up it MUST be winched down to the bed or it will fall, (been there done that :) hope this is what you needed, more questions? feel free to e-mail me back, Happy Holidays, BMW Rider
Dec 10, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Wolff Sunvision Pro 24S Tanning Bed Logo
328 people viewed this question
Top Wolff Health & Beauty Experts
Steve
NOEL
NOEL
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
