Question about Proscan Televison & Video
Tv and dvd hook up no color on tv from dvd movies
  • 57 Answers
What cables are you using, rca? if component
http://en.wikipedia.org/wiki/Component_video
it only carries vid, not audio so you may have plugged the two extra vid connections into the audio
if rcs like yellow red and whet, the yellow is video
Posted on Jun 02, 2014
2 Suggested Answers
SOURCE: We have a Panasonic DVD-S35 wont play color
We have a Panasonic DVD-S35 wont play color UK dvd's, US dvd's are ok any idea what's wrong?
Posted on Feb 23, 2010
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Mar 23, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 10, 2011 | Televison & Video
How to hook up a dvd player to a SHARP r19-m100
Ur tv have colors R,Y,W Video,Audio IN holes from the back or the front wright?The DVD player have R,Y,W Video,Audio out holes from the back wright?Used the AV component cable R,Y,W hook it up to the tv R,Y,W Video,Audio IN holes,the other side of the AV component cable to the back of the DVD player R,Y,W holes.Now u are all hook up and ready to play movies.
Oct 20, 2010 | Sharp 19R-M100 19" TV
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
I hooked my dvd player up to my tv. There is no sound
You have a great night too.
Happy DVD movies. :)
May 25, 2009 | Dynex DX-LCD37 TV
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Need instrutions for this model.
Please hook your dvd player and tv as follows...
Find Yellow color pin as Video Out, Red and White pins for Audio Out (right and left channels) and same goes to rear input-1 or input-2 what ever is available in your TV. watch out color of pins, same color in both units should be hooked up.
Now play dvd player and select input in tv and enjoy.
Still needs help, please mention model and brand of DVD Player and TV to guide you in better way.
Sep 29, 2008 | Televison & Video
No color on output of dvd movie
check for yourdvd system setting
Sep 20, 2008 | Televison & Video
Color on the screen
Try moving the speakers away from set.
May 11, 2008 | Orion1934 19" TV
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
