Question about Garden
Can't find were tachometer cable connects to engine drive
    Sergeant:
    Champion:
  • 266 Answers
What lawnmower has a tachometer?
Posted on Mar 21, 2014
Tachometer not working, how do i fix it
It's most likely the cable. If trans is not knocking or not shifting out of low range into the higher ranges with out slipping then you should be ok! CHECK your oil if dark red dirty. Get it service now not latter at a cert. shop. Let them know about the tact They will quote you a price then decide if it's worth it! It's a 1999 do you want to spend the money!.
May 18, 2014 | 1999 Ford Explorer
Tractor Repair for NH T1110
The tachometer is electric 12 volt current. It connects to the ignition coil.
Apr 23, 2014 | Garden
2005 Chrysler Pacifica speedometer and tachometer not working
you may have a bad instrument cluster and on yours the BCM run the cluster not the PCM
Dec 20, 2012 | 2005 Chrysler Pacifica
I have a 1994 Kia sportage 4 x 4 with an R2 diesel engine. the tachometer works erratically. most often it does not work and while driving sometimes it works. i see two wire connections at the diesel...
there are two wire beside the injection pump,,,, i think face the injection punp it is leftside... that's the wire sensore to the tachometer
May 12, 2011 | 1995 Kia Sportage
Keeps stopping and saying F06?? Any program its put onto it does this after a minute
Hi F06 suggests Drive Motor Tachometer Error, this means the Tachometer on the motor cannot detect speed or motion and the machine will stop.
Check the cables from the motor to the motor control unit making sure they are connected and undamaged also check for the same from the motor control unit to the main control board.
If all the wiring checks out and is secure the fault could be with the motor or motor control unit.
Probably best to seek the advice of a local washing machine engineer.
Hope this helps.
Feb 11, 2011 | Whirlpool Washing Machines
How to install tachometer in a 1984 chevy Blazer
Ok if you have a tachometer with 2 cables the positive must be connected to the ignition and the negative tachometer what conectaras the negative coil that way you worked well the tachometer
Mar 18, 2010 | 1984 Chevrolet Blazer
How do you time a toyota 4 runner 3.0?
22r-E, 3vz-E And 3f-E Engines
  1. Warm up the engine, then turn it OFF. Connect a timing light to the engine following the manufacturer_s instructions.
  2. Connect a tachometer to both battery terminals. Connect the tachometer probe to the IG-terminal in the check connector box. The check connector box is located next to the underhood fuse and relay box on trucks and 4Runner's; for Land Cruisers, the check connector box is on the firewall. Use the correct adapter to insure a tight fit on the terminal. Not all tachometers, particularly older ones are electrically compatible with this system. Read instructions for your unit before using.
Attach the tachometer as shown
3. Start the engine and run it at idle. Check the idle speed on the tachometer; adjust it to specification if necessary.
4. At the check connector, use a small jumper wire to short the connector at terminal T or TE1 and terminal E1, of the DLC1 as shown. Special service tool (SST) 09843-18020 or its equivalent can be used for this also.
Connect the SST or jumper wire to the TE1 and E1 terminals of the DLC1
This jumper will be used repeatedly during diagnostics in later sections. Take the time to make a proper jumper with correct terminals or probes. It's a valuable special tool for very low cost.
  1. Check the idle speed, then check the ignition timing. The 22R-E should read 5° BTDC, 3VZ-FE should read 10° BTDC and the 3F-E should read 7° BTDC. All of these readings are at idle.
On 3-FE engines, remove the rubber plug at the rear of the engine to view the timing mark
On other engines, the timing mark is visible on the crankshaft pulley
  1. Loosen the distributor pinch bolt just enough that the distributor can be turned. Aim the timing light at the marks on the crankshaft pulley (or the drive plate on 3F-E) and slowly turn the distributor until the correct timing mark aligns with the pointer. Tighten the distributor pinch bolt.
  2. Remove the jumper wire or special service tool (SST) from the DLC1.
  3. Check that the ignition timing advances. At idle the 22R-E should read 10°-14° BTDC, 3VZ-FE should read 8° BTDC, and the 3F-E should read 12° BTDC.
  4. Shut the engine OFF and remove the timing light and tachometer leads.
Mar 07, 2010 | 1991 Toyota 4Runner
Tachometer needle does not move after the engine is running
sounds like a bad connection on the outboard or the gauge
Mar 09, 2009 | Faria Chesapeake Series Tachometer
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
