Question about Andis BGRC
Cutting guides I am looking for cutting guides for my BGRC.
  • 193 Answers
No problem we have thousands, or you can just buy a pack of 3
Posted on Mar 24, 2014
Cuts are bowed
I heard that the rod that it rides on, may be bent. This is the rod, that you normally adjust, to get your straight cut, parallel to the blade. One mans solution was to turn the rods, so the bend of the rod, was vertical, rather than horizontal. You may want to look into ordering new , hopefully straight rods, from QEP too.
Jul 13, 2013 | Qep Tile Tools 83200 24inch Bridge Saw
Friction ring assembly of remington model eleven
Examine the chain saw to verify that the chain is still attached to the sprocket. If any part of the chain is not on the sprocket the chainsaw will not cut correctly.
Check the tension of the chain. If the lower part of the chain drops away from the guide bar, you will need to increase the tension. Remove the shield on the side case and loosen the nuts on the guide bar with the wrench. Pull the guide bar to increase tension on the chain and then tighten the nuts.
Clean the chain if it appears dirty. A dirty chain will not cut as efficiently as a clean chain. Loosen the tension on the chain and then take the chain off of the guide bar. Soak the chain in a solvent, such as mineral spirits.
Examine the sprocket on the chain saw. If it appears worn, bent or out of pitch, a new sprocket will be needed.
Examine the chain to see if there are any damaged drive links. Replace the chain if too many of the drive links are damaged because the sprocket will not turn the chain.
Examine the guide bar to see if it appears crooked or is out of alignment. Remove the nuts from the guide bar by following Step 2. Take off the old guide bar and then install a new one.
Sharpen the chain if it looks shiny. The shine on the chain indicates that the steel that is underneath the chrome plating on the chain has worn away. Use a round metal file on the steel until there is a thin overhang of chrome over the cutting edge of the chain. This will restore the cutting edge
Read more: How to Troubleshoot a Chainsaw Chain ' eHow.com http://www.ehow.com/how_6317552_troubleshoot-chainsaw-chain.html#ixzz1fLUkDPOc
hope it helps
Dec 02, 2011 | Remington Garden
How can I make my curly hair short but beautiful?
The best thing to do is to look at pictures of celebrities, http://www.stylelist.com has a lot of pictures and tips on how to get your hair cut, they have guides for how to get it cut depending on the shae of your face. Also here's a short guide on short curly hair: http://www.latest-hairstyles.com/curly/short.html
Good Luck
Apr 29, 2011 | Health & Beauty
How do i remove the detachable blade on the Andis bgrc
On some of these Andis BGRC clipper they have a lock hinge just pull the blade off with your hand some times they are hard to pull off.you may want to wear a glove so you will not cut your hand when pulling the blade off.
Feb 02, 2010 | Andis BGRC
I just bought a Skil Band Saw and it wants to cut to the left (as you look at it) it was being used to cut 16 gauge steel.I just changed the blade.
You probably just need to track the blade, pull all the guides back away from the blade and free wheel it by hand, tilt the blade into the center of the tires, if it doesn't center on both, one of them is off. When it centers, torque it up a little, then adjust the guides to the blade, don't push the blade out, just barely touch it, then it should track and cut straight. Good luck. Does this machine have a transmission for metal cutting? Or just one speed?
Feb 01, 2010 | Skil Saws
When cutting small sparks appear. It looks as if
It sounds to me as though you have incorrectly set the blade guides, in particular the bearing behind the blade that prevents the blade's teeth from passing between the guide blocks. If the bearing is set too far back the set of the teeth will pass between the blocks and may cause sparks as the teeth are literally worn away. It won't cut well for long if that's the case. Most saws have a bearing on both the upper and lower guides that is adjustable behind the blade, so that is can lightly rest against the back edge of the blade and support the cutting path between the guide blocks.
It's hard to say much more without knowing what model saw you're using.
See possibly these responses for help adjusting your saw: here, & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Oct 09, 2009 | Saws
Chain saw cuts at an angle
I have seen this problem of a chain saw cutting at an angle brought up again and again on forums, and result in a variety of answers about sharpening the chain, or replacing the bar and/or chain. In a number of these requests for solutions, none of the advice has solved the problem. I have used chain saws for about 45 years now, and there is a condition that some chains develop with the pitch of the teeth or the guides...or both...that will cause them to cut to the left or right at an angle (usually left). While I have not figured out what causes this, I have solved the problem of correcting it. First, turn the nose of your bar and chain toward you on a bench, look down it like sighting a gun and take a look at each tooth and guide. If the saw is cutting left, the teeth or the guides (or both) on the left (while you are looking down the bar from its tip) will be pitched differently than the teeth and/or guides on the right. The pitch of those teeth or guides (those little ears that stick up about on-fourth inch in front of each tooth) will be: 1) too much in line with each other, or 2) the teeth or guides will be less pitched than the teeth or guides on the right side of the chain. Solution: take a large pair of lineman's pliers or similar pliers and pitch those teeth and guides to match those on the right side of the chain. Also, make sure the curved part of your chain teeth peek out around the outside edge of those guides. If the guides are directly in line with your teeth, they will hinder cutting by the teeth. You can do this with the chain on the saw if you don't have too much slack between the bar and the chain. Last, make sure that the chain guides are not as tall or taller than your teeth. If they are, you will need to file them down a little (with a flat file) until the teeth are slightly longer than the guides. Afterward, make sure the teeth on both sides are equally sharp, and go cut a straight cut! TennesseeBob
Jan 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Andis BGRC Logo
48 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
