Question about Juki Sewing Machines
Install dell wireless 5530
Hi my machine is havin problems stiching it makes a few stiches then dosent wat is wrong wid it iv tried everything
  • 64 Answers
Machine out of time. theres a mark on needle bar that aglins with the needle bar guide. when u have the needle in this position u have to loosen the hook ( 3 screws) and place the point of the hook just meeting the needle. before u try this try lowering the needle slightly.
Posted on Apr 11, 2014
SOURCE: Sewing machine not making stiches
At first, my machine was getting all tangled under the fabric and then would stop working because it was tangled in the bobbin area. Now the bobbin area is staying clear but there are no stiches being made. I have no idea what to do. melissashulga@yahoo.com
Posted on Sep 17, 2008
  • 3 Answers
SOURCE: stitching problem
You can get the manual for this machine at the Brother site.
http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/doc/manual_top.html?reg=eu&c=eu_ot&lang=en&prod=hf_xl5130euk
Posted on Sep 25, 2008
  • 323 Answers
SOURCE: JANOME MEMORY CRAFT 8000 - TENSION
You need to do the following:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
If it still messes up ,remove the bobbin case and examine it for burrs or scratches. Remove them with and emery stick and fine steel wool.
sewman7
Posted on Nov 04, 2008
dupina
  • 110 Answers
SOURCE: singer 533 missing stiches
Replace your sharp needle, code 2020, with a ball point needle, code 2045. This usually solves the problem. You can also put "Stitch and Tear" at the bottom to help stabilize the material. If you can do not have Stitch and Tear, try a piece of tissue paper for the short term.
Posted on Dec 22, 2008
kirkx
  • 2019 Answers
SOURCE: I have a janome 8050
The key to proper stitches is that tension on the bobbin must equal the tension on the upper thread spool as well. The bobbin has a tension screw that may have come loose or the thread is not properly in the tensioner. For example, the bobbin could be in backwards. Or the tension of the top could be too light and allowing the tension on the bottom to pull the thread down too much.
Open the bobbin tray and watch while you slowly rotate the hand control to see it make a stitch.
You will probably be able to figure out what is wrong.
Posted on Apr 08, 2011
Why is the bobbin thread being cut on bobbin after a few stiches? machine will sew a few stiches and this happens.
your bobbin is place in the wrong position and you need to tighten the stitch....adjust it a bit.....play with it till you get the desire result
Sep 11, 2014 | Singer Sewing Machines
1960s Elna Supermatic - lower thread only catches sometimes
Make sure you have the correct needles for this machine and that it is fully inserted into the needle bar and correctly oriented.
Mar 20, 2013 | Sewing Machines
My sewing machine will not stich. i have tryed everything i can find on this problem but nothings working
Make sure nothing has either gotten stuck/caught/jammed somewhere inside it. Insure that the thread stays attached to the needle. Or the material you are trying to sew/stitch may be too thick.
Nov 17, 2012 | Singer Sewing Machines
My machine is baby lock.it suddenly got a problem.it is: it sews a few stiches and stops and it goes on like this
here are some suggestions, if the suggstions don't help then it
would be a good idea to have the machine check to see if something
in wrong with the computer part of the machine
1. change the needle--make sure it's the right needle for the fabric
2. rethread the machine top & bobbin,,make sure to use every
thread guide
3. make sure the bobbin is turned the right way in the bobbin case
4. clean under the needle plate & in the bobbin area for lint
Oct 12, 2012 | Baby Lock Sewing Machines
Machine skipps stiches whats wrong
You need a heavy duty needle #16 or #18 to sew leather and teflon presser foot is helpful
Apr 15, 2010 | Singer 7442 Mechanical Sewing Machine
Tread breakage snd stich skipping
(A)Put in a new needle and rethread from the beginning. Make sure the take-up hook is threaded. Also, (B) clean lint out - sewing machines have very small margin for error when lint pushes everything out of alignment. Mostly, it sounds like your thread is stuck somewhere, which can even be at the spool, so (A).
Apr 06, 2010 | Juki DDL-8700
Does not make a stich
you may find that the needle is bent. or maybe the machine needs a cleaning I use canned air for this it blows the lint out so nicely . if this is a new machine then take it back to where you bought it and see what they can do.
Feb 26, 2009 | Singer 3116 Simple
Trouble with sensor
The upper thread sensor on most Brother's is activated by the check spring. Either your check spring has broken or is stuck. You may be able to fix this if you can get to it. A drop of oil may be all you need. I may be able to give more specific advise if you tell me what model it is.
Feb 06, 2009 | Brother Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
