Question about Lite On Lite-On DH-20A4P 20x Dual Layer DVD?±RW IDE Drive (Black) Burner
Mechanaism out of time
I open the drive to lubricate it and now I can not assy it again. It looks like the mechanism is out of time-
    Sergeant:
  • 376 Answers
I think you would need to assemble in the reverse order or disassembly. Don't tell me you didn't take notes and pictures. You needed to take it to a professional. I lubricate my drives about twice a year and I don't have to disassemble anything in order to do that except for cover removal.
Posted on Jul 04, 2014
1998 vw polo. the front manual window is hard to close and open. what is the easiest way to fix
Shoot WD-40 into the assy. Chean tracks. Remove door panel and check alignment guides on the front and rear of the window tracks. Check for a bend in any of the regulator arms. Lube the mechanism with the recommended lubricant.
Oct 14, 2011 | Cars & Trucks
The washing machine tub is frozen will not move at all
This is a mechanical fault in the drive mechanism that has struck the tub. It this has a gear box then it can be within the box that a drive is struck. So open the box and reset. Please also look for any foreign articles that have come out of the clothes which has got struck into the drive.
A manual turn of the drive will ensure the point of jamming which needs a reset.
Remove and replace after good lubrication on required links.
Jan 22, 2011 | Whirlpool LHW0050PQ Front Load Washer
I've had this computer for about 11 years now and the dvd drive will not open, i pried it open once with a paperclip but now it won't open again. It's been like this since I can remember so probably three...
The best way to fix this problem is to re-build the drive. I would take it apart, lubricate the mechanical areas, and replace the belt that is connected to the pulley and the motor. Sometimes this belt will slip and prevent the mechanical operation. If the motor spins but nothing happens, then the belt is bad.
Jan 21, 2011 | Sony VAIO Digital Studio PCV-RX540 PC...
Chevy uplander rear liftgate will not unlock
The tailgate on my 2008 Chevy Uplander refused to open. The unlock fuse was fine. The handle pull worked fine. I could even hear the little motor that unlocks the tailgate whirr when I pushed the unlock button. But the gate would not release. Turns out the problem was the lock mechanism was jammed because it had dirt in it and not enough grease. From the inside, I pulled the lift gate panel out at the window so I could look down and see the lock mechanism at the bottom of the lift gate. I reached down and prodded it with my screwdriver until I noticed that parts of the mechanism weren't sliding back and forth like they should. I sprayed it with a silicone lubricant until the parts started working again. Finally, the lock unlatched and I could open the rear hatch. I could then remove the entire plastic panel and remove the lock mechanism. I found that the mechanism has lots of rubber and plastic parts which get chewed up and start to jam if not properly lubricated. I cleaned out the dirt with my silicone spray and thoroughly lubricated all the moving parts. The latch now lets go of the post very easily, and the lift gate no longer gets stuck.
Nov 19, 2010 | 2005 Chevrolet Uplander
Rear door latch freezes - 2002 Toyota Avalon
Looks like dirt, moisture and others have combined to clog the linkage mechanisms of your lock/latch.
You would need a can of lubricant such as WD-40. Spray the lubricant on the lock/latch, and try to close the door. Repeat as necessary and watch what happens.
Once the latch begins to operate, dab some clean engine oil to the latch again, this wiould ensure long-life trouble-free operation.
Dec 20, 2009 | 2002 Toyota Avalon
2002 hse freelander sunroof motor buzzing at certain points
My sunroof has played up as well and it is all down to lack of use. The lubrication LR use for the guides and the drive mechanism appears to harden over time causing the mechanism not to work correctly. There is a light oil available from LR to lubricate things but in my case the lubrication already there was like a grease so after opening the roof and then protecting everything with cloths, I applied WD40 through its nozzle to the sliders and the spiral drive mechanism and then operated the sunroof a large number of times giving it a manual helping hand. Eventually it worked ok.
Mar 24, 2009 | 2002 Land Rover Freelander
Tail gate wont stay closed -latches not catching
I had this problem with my 2004 for the past year. Then this past week end it stopped latching all together. I found on mine the handle mechinism froze up. All the wd40 I tried did not help. I had to replace the handle. one thing I saw that could be a problem if it has happened since owning is if the connecting rods that go from the handle to the side latches are not adjusted right. they clip into the handle mechanism and if they were cannected with latch down they may not move enough to allow latch to lock completely.
Jan 04, 2009 | 2004 Chevrolet Avalanche
2000 Dodge Caravan Rear Door Latch
I had the same problem and fixed it using the following steps. I am not an expert or even very mechanically inclined, just desperate to get this fixed without spending any money. This was done on a 1996 Dodge Caravan. Similar steps should apply to a number of years of the Caravans and Voyagers.
Two people will make removing the panel easier. To do this, you'll need a phillips screwdriver, penetrating lubricant, and pliers.
First, if you cannot open the door at all: There is a small plastic disc plugging a hole just above the latch on the inside. Pop out that disk, and use a screwdriver to lift the latch mechanism. It should not take a great deal of force to move the latch. When the latch moves, push the door and it should open.
1. Remove the plastic panel on the inside of the van. You need to remove the handle and several screws on the perimeter of the door.
2. Disconnect the interior door lights by gently pulling the wiring harness (two of these).
3. Looking at the door from the interior, there is a small electronic plunger mechanism on the right side with an "accordion" (this is the electric lock). There is a rod that goes from the to the middle of the door, just above the lock mechanism. Another rod goes from the key lock to the latch. This rod, threaded on one end, snaps into a small bracket on the latch. It may need to be snapped back in. There may also be a rubbery/tar-like sticker near the locking mechanisms that can be removed (it can interfere with some of the moving parts).
4. Manually operate the plunger on the electric lock several times using pliers. Mine was extremely stiff. It should move the rod at least a full inch.
5. Spray lubricant on the latch, the back of the key lock, and the back of the exterior handle. Also spray lubricant into the key lock itself (where the key goes). Do NOT spray lubricant on the electronic lock mechanism or plunger.
6. Just above the latch, there is a small hole (only about 1/8" around). Carefully and liberally spray lubricant into that hole in every direction (this is where the rods from the key lock, electric lock, and latch meet). There is a white plastic post that comes out through another nearby hole. Spray lubricant liberally into that hole, too.
7. Again, manually operate the plunger on the electric lock several times using pliers. It should be considerably smoother to operate.
8. Put your key into the key lock and pull it out several times.
9. Spray lubricant into the key lock again, then carefully operate the lock with the key. If it didn't work or was stiff before, it should operate much more smoothly. Operate the electric locks several times.
10. When operating the lock, you should see the plunger on the electric lock move to its extents (at least an inch). Watch it when using a key and using the electric lock.
11. Check the movements of the rod and plunger when operating the lock, and the movements of the latch when operating the handle (when unlocked). If anything is still really stiff, use some more lubricant and operate the lock and handle again.
12. When reassembling the door panel, remember to plug in the two wiring harnesses for the interior lights.
I hope this helps!
Jul 06, 2008 | 2000 Dodge Caravan
Lite On Lite-On DH-20A4P 20x Dual Layer DVD?±RW IDE Drive (Black) Burner Logo
41 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
