Question about Proscan Televison & Video
Tv and dvd hook up no color on tv - Proscan Televison & Video
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Is it a tv with dvd combo?..if so..then opening the tv and cleaning the dvd player may help..if not then the dvd unit is suspect..if its a separate dvd player and your using rgb or component cables..you may have a bad cable/connection
Posted on May 12, 2014
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
How can i hook my dvd player to the tv
Color codes on cables must match up to matching colors on dvd player
Nov 05, 2014 | Monster Cable J2DVD-CHP10 Just Hook It Up...
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 10, 2011 | Televison & Video
No color when playing dvd
try to connect cables again. make sure you push them strongly to maka sure it works. if that won't work your dvd or tv is damaged
Apr 06, 2010 | RCA Televison & Video
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
Oct 17, 2009 | Televison & Video
We just received a big screen tv as a gift and we want to hook up our dvd player and our vcr and have lost the manuals. HELP
You can hook your dvd player in tv by using component video input terminal having green-red-blue colors for video signal and red-white for audio signal. so total 5 wires been used here. color order should be exact at both units, tv and dvd player i.e green to green, blue to blue and so on.
vcr can be hooked at composite video input in tv having 3 pins, yellow for video, red-white for audio in both units, vcr and tv. pins color should be exact on both units.
need further help, post here please.
Sep 24, 2008 | Televison & Video
Hooking it up
Easy, just match up color codes from tv to dvd player. If you only have red, yellow and white, they should coincide wih the TV as some TV's dont have the 5 color jacks R/W/G/B/Y inputs. If they do, use the colorstream or "comp" input on the TV
Mar 03, 2008 | GPX D1816 DVD Player
Hooking up wii
you can do it multiple ways. like putting the cords into the dvd then putting the dvd cords into the tv, or put it into the tv, or hook it up to satilitte and hooking up to the tv. your choice.
Dec 26, 2007 | Nintendo Wii Console
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
Televison & Video Logo
88 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
