Question about Miele DG 4080 Stainless Steel Electric Single Oven
Replacement Door Hinges Miele Oven
Good morning,
I am trying to source some hinges for a Miele double wall oven.
Details are:
Miele DE LUXE H 609
I was unable to locate these on your site, but was wondering if you were able to source these ?
Thanks for your help.
Regards,
Ian Foletta
  • 177 Answers
Hi the only place to purchase Miele spare parts is through Miele directly or from a Miele authorised service agent
Posted on Sep 02, 2010
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Door does not close all the way
Good Morning Richard, thank you for allowing me to assist you!
If the door does not close all the way, there is a possibly that the issue lies with either the door gasket or the hinges. The door gasket may be worn or torn and the hinges may need to be adjusted or if they are too damaged, possibly replace. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Dec 16, 2013 | Frigidaire 30 in. Electric Gallery Series...
How do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Frigidaire 30 in. Electric Gallery Series...
Door does not shut completely
OVEN DOOR HINGES WILL NEED REPLACEMENT IF YOU PUT ADDITIONAL WEIGHT ON THE DOOR THEY WILL SOFTEN THE SPRINGS AND THE DOOR WONT FULLY CLOSE.
May 29, 2010 | Electrolux 30" Built-In Double Electric...
One of the oven doors does not close tight so heat escapes. It is a Jenn Aire electric double wall oven model number JJW9627DDS.
Sounds like the oven door hinges have worn. If door is not obstructed in any way and will fully close when pushed but open about half a inch when released then it will be the hinges. Not sure of cost of spairs. I believe this to be a John Lewis Model. If it has a Enr no inside the door or inbetween the door hinges then I could give you price on spares
Nov 15, 2009 | Jenn-Air JJW8230D Electric Double Oven
Thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Jan 13, 2009 | Thermador C302U Electric Double Oven
Smeg Double Oven SD08
this can be hard to do as you should have locked the hinges with the door fully opened before taking it off. the hard part now is (with the door off) you have to push the spring loaded hinges down and lock them with small hook located on each hinge once locked the door will go back on the oven. you then open the door fully and unlock the hinges, good luck
Feb 17, 2008 | Smeg DO81CSS Electric Double Oven
Miele DG 4080 Stainless Steel Electric Single Oven Logo
1,418 people viewed this question
Top Miele Ovens Experts
Paul Bade
John
Marvin
Marvin
Are you a Miele Oven Expert? Answer questions, earn points and help others
