PC says Masterboot is missing and I can't get on PC
  • 2,072 Answers
Assuming this is a windows computer. You will need to get on another windows computer and create a recovery disc. Then boot to that disc on the non booting computer. Enter the recovery console and type fixmbr, then reboot the computer
Posted on Mar 19, 2014
Master bootis missing
what version of the OS do you have?
you probably need to install the os fix from a recovery cd.
Mar 17, 2014 | Computers & Internet
No bootable partiton in table
WHAT DO YOU MEAN,WHEN YOU INSTALL Os YOU INSTALL MBR.(MASTERBOOT RECORD IS IT CORRUPT YOU HAVE TO REBUILD IT
Jun 06, 2013 | Computers & Internet
(Error code: WHD16-QW1
no MBR masterboot record.WINDOWS will not boot.?DETAILS,YOU FORGOTT ABOUT THE DETAILS.
May 25, 2013 | Dell Computers & Internet
Acer error
after what i understand you have to rebuild MBR (masterboot record).roberto to able help i need moore information.can you get in to safe mode ? .
May 21, 2013 | Acer Aspire T180 PC Desktop
How do I fix error codes pxe-e61 and pxe-mof
The fix will depend on exactly what is wrong. The messages mean that your computer can't read the hard disc and find a boot OS. The drive may have failed, the cable might be loose, or the MBR (masterboot record) is bad.
First make sure that you do not have a CD/DVD in your optical drive, a floppy in your 3.5" drive or an external hard drive attached to one of the USB ports. (The computer may be trying to boot to one of them.)
Next press F2 when you turn on the computer (press repeatedly). This will let you enter the BIOS to set the disc boot order. (Check that the hard disk is listed first. This also indicates that the computer sees a hard drive in the machine.) If you get the error message again, try the entire procedure again from turning on the computer.
Next try using the appropriate Windows install/update disc to repair your system.(The Dell 4600 came with XP and you need the correct SP on the disc. If you kept up on the updates, it should be SP3.) Put the CD in the optical drive then restart the computer. Press F12 repeatedly to get the boot selection menu. (The same repeat routine may be needed if you miss the timing.) Use this disk to enter the Recovery Console and attempt to repair the Master Boot record.
Use the directions here: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/index.htm to check if the cable is connected properly. You will need to open the case.
This Dell came with an IDE hard drive. These often have a jumper that indicates the boot order. The jumper must be set to master or cable select and be attached at the master position on the IDE cable. This is the connection at the very end of the cable. The IDE cable can come loose from the motherboard, as well. You can also try a different cable.
The final option is to replace the hard disc. Unplug the old hard drive from the IDE cable first. You'll need the Windows install disc and then to reinstall all of your drivers and programs. Move the bad disc to the slave position on the IDE cable. See if you can salvage any of your files from the hard drive. (Sometimes, putting the drive in a ziploc bag and placing it in the freezer for several days will let you read the disk when you put it back in the computer.)
I hope this helps.
May 03, 2012 | Dell Dimension 4600 PC Desktop
I did a system restore from the disks. Everything
you will need to reload the window NTLoader is not reading your masterboot record. reinstall windows again make sure the disk is clean .
Nov 17, 2009 | Acer Aspire 3100-1405 Notebook
Missing ntdlr
hi
see this link for ntldr missing problem,
http://www.computerhope.com/issues/ch000465.htm
Apr 19, 2009 | Computers & Internet
Sata concetion
SATA HDD's do not have master/slave/cs jumpers like IDE drives do because only 1 cable is connected to each drive, so you have to plug whichever HDD you want to be primary into the SATA0 port (or SATA1 if there is no SATA0) on the motherboard.
Also make sure you have your masterboot recrod installed on the drive you use to boot.
Jan 22, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Sometimes it boots sometimes it wont
Hello Mike:
Sometimes is the trouble here..but lets go through a few things to check...perhaps maybe one of mine someone else didn't think of...
1) remove the battery and unplug from the wall. Hold power button on...plug into power...let boot.
2) Perhpas it is software related...your MBR could be corrupt...boot to DOS (you can create a dos diskette from boot.com) or simply hit F8 to boot in DOS mode. at the C prompt type FDISK/mbr. This will not harm your data...it will rebuild your Masterboot record. There a few nasty viruses that hide in the MBR (Master Boot Record) running this ustility will wipe it out.
3) On the otherhand you could have a more serious problem...motherboard or CPU. TRoubleshooting this items in a laptop is a bit trickier than a desktop...you could purchase one of those troubleshooters for about 20 bucks...you plug intoLPT1 and USB...power laptop and read the lights.
Hope I have been soem help...
Good Luck my Friend
Seek PC Repair
Feb 10, 2008 | Sony VAIO GRX580 Notebook
Computers & Internet Logo
David Payne
David Payne
