Just put a hdmi into my packard bell viseo243d and now the display is too small for the screen
SOURCE: screen flicker/jumping
first check loseconection and tube light and nearaset spk for sparking .and check the earth of monitor main waire
SOURCE: my packard bell viseo monitor makes my pic's to wide
This issue is caused by missing drivers. You may need to install the drivers (Video card drivers and the Display drivers), the setup will set the adequate resolution for the display so the images will be displayed correctly.
SOURCE: my packard bell monitor keeps presenting a blank
Try this for starters. Shut down the computer like you normally do. Next turn it on and while its booting up press the F8 key(keep tapping it). You should get a menu and on that menu, one of the choices is Safe mode. Select it and press enter. This will boot your computer into a Diagnostic mode where you can troubleshoot hardware software and windows problem in general. If you successfully get into safe mode answer yes to the question it asks and then goto your Device manager..you can get there by rightclicking the mycomputer icon and select properties from the drop down menu then select the Hardware tab on top.and click DEVICE MANAGER. In this screen look for your display adapter..higlight your graphics adapter and right click...then select uninstall...now reboot your computer normally this time dont press the f8 key..gointo WIndows normally. This should reinstall your graphics card and possibly fix the problem.
