Question about Asko Dishwashers
Asko dishwasher D5644 won't start
Dishwasher won't commence wash when using touchpad. Also can't turn off with touchpad. Able to change the cycle but not turn on.
  • CavMum Mar 18, 2014
    Great help thanks...Asko service technician booked.
  • 1,511 Answers
The pad has several sequential functions, all independent from one another, but they rely on the main circuit board to send the proper signals for various functions. The start and Stop function can be compromised if a shot occurs on the key pad. Since the Start is shorted, the Stop cannot operated as it has noting to do at this point. Rather than waste money on replacing the touchpad and doing it yourself, it is best to have a reliable technician do a continuity test to see if it needs replacing or a common problem exists elseware.
Posted on Mar 18, 2014
SOURCE: Asko dishwasher problem
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
Posted on May 29, 2007
  • 351 Answers
SOURCE: Dishwasher Asko D 1776
you may need to reset the inlet time on the board do you have the instuction book,turn the power on then press the fifth button five times within 15 sec then press third button normal wash this should fix your problem
Posted on Apr 09, 2008
  • 14 Answers
SOURCE: Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Posted on Jun 18, 2009
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
Same thing happened - couldn't do anything - was completely "locked"...tried the breaker reset and it worked immediately. Thank you for sharing the answer!
Posted on Jan 10, 2010
  • 128 Answers
SOURCE: when dishwasher is switched on to start its
Following is a complete trouble shoot for your dishwasher.
Most probably a float valve or alignment of the door interlock switch.
Start with the simple things and work your way from there. You will be amazed how many people call a plumber who flips a breaker or simply clears a stuck float valve (for $80 minimal fee).
If no lights are coming on.
First check the breaker to the machine.
If you have an exposed power source to the machine such as a plug or junction box open the box and check the wiring is intact and not rusted etc. Take care here and shut the breaker off first.
No go so far?
Check if your float valve is jammed.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
Not the float valve either?
Check the door interlock latch.
Much like a washing machine a dishwasher will only operate with the door closed (or when it thinks it is closed!). There is a metal tab that engages a switch in the door. This is the same switch that activates as you operate the handle to open the door. If it is misaligned it will not signal the machine that the door is closed and the machine will not operate.
You can check this by overriding the locking tab. Put a screwdriver in the door latch and press the switch. You should see the lights come on and power flow to the machine.
Note: if the machine is in run mode you will get water spraying.
To fix this problem bend the tab to properly engage the switch. Or if necessary loosen the screws retaining the switch and move it to correctly align with the tab.
Not it?
OK now you are into electronics.
First is quite simple. Some units have an internal fuse to protect the control panel. Check that first. Take your time and take care. Turn the breaker off.
The control panel is screwed in place. Remove the screws and gently remove the control panel. Take care not to have parts of the door latch fall out or springs drop out etc. On newer units it is very simple as it is just a circuit board. Look for the fuse and check that it is OK. Replace if necessary with correctly rated thermal fuse.
Do you have water in the bottom of the machine?
Power is there, lights are one, seems to want to work. Water will come in but will not drain.
A small amount around the drain is normal for some machines. This is held to keep the pump primed in some units. However it should not fill the bottom of the unit. You know what it normally looked like so it if is full then you probably have a jammed float valve as above or a clog in the drain.
Drain clog.
Remove the cover from the drain in the bottom of the dishwasher. They usually lift out or have a few screws holding them down. Simple to figure out just take your time and try not to force anything. Look for a clog and clear if necessary.
Your drain can run either direct to the drain under the sink or to the disposal unit if you have one. The drain can clog at either point.
Check by disconnecting the drain line from the dishwasher where if connects to the sink or disposal unit. Look for a clog and clear if necessary.
Water exits the machine via the drain pump. If it is not operating the machine will not drain. It will fill usually to the point where the float valve lifts and does its job by stopping the machine before if floods your house.
If you have water in the machine to the point the float valve is lifted then drain it out first.
Your machine should be running now. Lights will come on and it will run again to the point where if fills with water and trips the float valve again. If so then check the pump and timer (see also timer below).
Remove the units as per below.
If your pump is belt driven check he belt (very few have belts).
If direct drive switch the unit on and let if run to the drain cycle. If the pump does not come on check for voltage at the pump during the drain cycle. If you have voltage replace the pump. If not it is the timer that is faulty (see below).
OK now your are getting to some deeper issues. Not necessarily hard but only go here if the simple things are OK.
If you are not getting water into the unit but you have lights on and you hear clicking and the timer runs and things are trying to work then we know you have power and the timer is running.
No water coming to the unit.
Make sure nobody shut the supply line off. There should be a tap under the sink on the water supply line to the unit.
Turn the unit on an listen at the base for a click as the water supply solenoid (electric switch) opens. No click?
Check the solenoid. Remove the machine from under the counter. There will be screws holding it to the underside of the counter. You may have to lower the legs to get it out. They turn with a wrench to lower.
Under the unit where the water supply line comes in is a solenoid switch it opens to allow the water to enter the machine. Water comes in under household pressure (it is not pumped in by the unit). Chances are it is faulty. Replace it as it can't be serviced.
Still no luck?
The unit is guided by a timer. The timer tells the machine what to do and for how long. If it fails the unit will stop or jam in one cycle. If you have a physical switch the you turn to select the type of wash cycle check it. If you are all touch control then replace the whole board or machine.
To check the switch open the control panel above and use a voltage tester to see if you have current at each cycle point. Cleaning sometimes helps if not replace.
Hope this helps you. Please rate this tip for me.
Adrian
Posted on Mar 16, 2010
Is my asko d1776 repairable. It's currently not going into wash mode. The Blade are not turning and washing.
The motor is not getting switched on at the proper time. The timer / cycle selector is the problem and is easily repairable.
May 25, 2015 | Asko D1776 Stainless Steel Built-in...
New dishwasher won't wash
What noise does it make?
Jun 09, 2013 | Dishwashers
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Sep 28, 2012 | Dishwashers
Asko dishwasher did not finish complete washing cycle and now has a very low humming sound. It will not start washing cycle. I have turned it on and off but after I turn it back on humming sound...
Some wash water may have gotten into the bottom pan area below the wash tub. If water has overflowed from the tub into the bottom pan, the drain pump will activate and remain active until water has been removed from the bottom pan. To check for this, the lower front panels will need to be removed. With power turned off at the breaker, a wet-vac can be used to remove water from the bottom pan. If there was water there, check the door seals, door closure and make sure the drain hose has a high-drain loop. If the drain is shared with the kitchen sink, it may simply have backed up into the dishwasher through the drain hose when a full sink was emptied. The best drain system is for the dishwasher to have its own separate drain.
Jun 29, 2011 | Asko Dishwashers
Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Mar 26, 2010 | Asko 24 in. D3250 Built-in Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Asko Dishwasher 1473 - 262
The sound is the drain Pump I believe ,it turns on to make sure the unit is clear of problem so it can re cycle and start again.
Jun 12, 2008 | Asko D1716 Built-in Dishwasher
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Dishwashers Logo
598 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
