Question about Moultrie Game Spy M-880
Security code I enter my 5 digit code but it stops on the last digit and the last digit just sits there and flashes. pushing enter or menu does nothing
Security key on and bike wont start
First, open fob and make sure battery is making good contact and no corrosion on contacts.
Also, you might need a new fob battery.
Finally, if you know the security code, you can disable the security system.
DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Turn IGN to IGNITION.
Quickly (within 2 seconds) hold BOTH turn signal switches until confirmation signal (KEY icon flashes at fast rate, in odometer window, a flashing "-" will be followed by 4 more dashes = "----")
Enter 1st digit (a) in PIN by pressing LEFT turn signal switch (a) times (i.e., 5 times for the number 5)
The 1st "-" will become the 1st digit (i.e., "5")
Press RIGHT switch signal 1 TIME.
The 1st digit is stored and the dash will flash.
Enter 2nd digit (b), and repeat sequence until done.
After the 5th digit is entered, the KEY icon stops blinking, and the system is disarmed.
The system will stay off until the IGN switch is turned off.
If at any time during disarming sequence an error is made, wait 2 minutes before trying again.
Mar 16, 2013 | 2008 Harley Davidson FLHX Street Glide
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
I HAVE A 2007 HARLEY DAVIDSON CLASSIC SOFTTAIL. SECURITY SYSTEM PROBLEM. I HAVE REPLACED BATTERY & KEY FOB STILL COMPUTER WILL NOT ALLOW ME ENTRY TO DISARM & WILL NOT CRANK. DID STEP BY STEP OWNER...
If you do not know the security code, you can reset it to your own choosing.
With the fob present, turn IGN switch:
IGNITION-OFF-IGNITION-OFF-IGNITION
Press LEFT turn signal switch 3 TIMES
Press RIGHT turn signal switch 1 TIME and release
Turn signals will flash 3 times. Current PIN will appear in odometer. The first digit will be flashing.
If changing PIN, enter first digit (a) of new PIN by pressing LEFT signal switch (a) time(s) i.e., for the number 1, press one time. for the number 5, press 5 times.
Press RIGHT signal switch 1 TIME and release.
the new digit (a) will replace the current in odometer window.
Enter second digit (b) with LEFT signal switch.
Repeat until PIN is set.
Once PIN is set (either new or old PIN), to disarm security system, DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Feb 28, 2013 | 2007 Harley Davidson FXSTC Softail Custom
Changed battery on my 2007 streetglide and system not recognizing my fob so not starting
Yes, you do need to take it to dealership to match the fob.
BUT, to get it to the dealership, you can bypass the fob IF you know the security code.
Feb 23, 2013 | 2007 Harley Davidson FLHX Street Glide
Need to bypass the security fob. Won't start
You can bypass the fob IF you know the security code.
Nov 08, 2012 | 2007 Harley Davidson FLHX Street Glide
I have forgotten my unlock code to lg revere
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
Aug 02, 2012 | LG Revere MobiPhone - Black Verizon...
Forgot my flip camera security code
  • 1 Enter the number you think is your 4-digit unlock code. Do it once slowly, so you don't waste the number of tries you're allowed before the cam completely locks. If you never set a code, try 1234. The factory sets this as the default. If that fails, try the last four digits of your home phone number. That's the default of some network providers. If all these fail, go to Step 2.
  • 2 Click the menu key, which has horizontal lines on it. It sits between the left and right soft keys and above the round 5-way navigation keys. You should now see the unlock code bypass screen. Enter your 6-digit security code. Select "OK." If this doesn't work or you don't remember your security code, go to Step 3.
  • 3
  • Try 000000 as the factory default setting for the security code. If that doesn't work, go to Step 4.
  • 4 Call your network's customer service center. Locked ones usually let you call both customer service and 911. However, calling on a separate phone will make entering the code they give you easier to enter and test while they're still on the phone with you.
  • HID KITS.
    Jun 01, 2012 | Pure Digital Flip Video Camcorder
    How do I clear all information from a LG VX5500 Cell Phone before returning it.
    Steps to Reset Settings
    This resets the phone to factory default settings.
    1. With the flip open, press the OK key [Menu].
    2. Press 9 or Settings & Tools.
    3. Press 6 or Phone Settings.
    4. Press 7 or Security.
    5. Enter lock code. The default lock code is the last 4 digits of your phone number.
    6. Press 5 or Reset Default.
    7. Press OK after reading the warning message.
    8. Select Revert by pressing OK. A confirmation message is displayed briefly before the phone resets itself.
    Steps to Restore Phone
    This erases all user data and contact information entered in phone memory.
    6. Press 6 or Restore Phone.
    8. Enter lock code. The default lock code is the last 4 digits of your phone number.
    Sep 14, 2011 | LG VX5500 Cell Phone
    Lights on the bike flash and the bike will not start, can anyone help?
    If you have a factory security system with the sensors located inside the key fobs you probably need to replace your fob battery.
    Aug 08, 2010 | 2008 Harley Davidson FLHX Street Glide
    Due to remove the car battery from my car the stereo akking me for code (password) I know what is it, but where is the enter key on the detacheble face
    1 Enter Standby
    2 Enter Menu mode
    When "MENU" is displayed, "SECURITY" is
    displayed.
    When "ENTER" is displayed, "CODE" is displayed.
    4] or [¢].
    Security Code.
    When "RE-ENTER" is displayed, "CODE" is
    displayed.
    "APPROVED" is displayed.
    Good Luck
    Jan 12, 2009 | Kenwood KDC-MP528 CD Player
    Moultrie Game Spy M-880 Logo
    77 people viewed this question
    Top Moultrie Video Cameras Experts
    J.D. Browning
    J.D. Browning
    Andrew Taylor
    Andrew Taylor
    Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
