Question about Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Sync
Changed the batteries in both units can't get the time to change how do I manage that?
Do I have to take both batteries in each unit and wait 10 minutes and replace and hit the reset button on each unit
  • Diane Greene Mar 19, 2014
    I finally have fixed thank you
2 Suggested Answers
  • 17 Answers
SOURCE: I changed batteriers and now I can't get a reading
I believe they ask you to press the reset button on the main unit first, but that may not be your problem. Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. Also, make sure the units are close enough to transmit.
Posted on Oct 21, 2010
Model WS9611UN-IT - I am unable to receive the outdoor temperature. I have changed the batteries on the outside remote but I still do not receive the outdoor temperature. How can this be corrected
Remove all batteries, both outdoor and indoor. Install batteries in outdoor unit and wait for it to begin sending a temperature signal. Install batteries in indoor unit. You should see outdoor temperature displayed. If not, batteries, transmitter, or indoor unit may be defective.
Nov 16, 2016 | Measuring Tools & Sensors
Out do I get the outside temp back.
You have to remove all batteries, both outdoor and indoor. Install replacement batteries in the outdoor unit. Back indoors, install replacement batteries in the indoor unit and wait for temperature to be displayed. If nothing happens, the outdoor unit may have failed.
Jun 17, 2016 | Measuring Tools & Sensors
I changed the batteries in both the main unit and remote unit. I can get the date and time on the main unit, but not the temp. How do I fix this?
I don't have this particular unit, but with the one I have, you have to power up the main unit last to get it to sync with the external unit.
Aug 12, 2014 | High Sierra Atomic Travel Alarm Clock BK...
Indoor unit and outdoor unit not connecting
If the outdoor transmitter and indoor receiver communicated for a time and now don't, it could be time for a battery change. The usual procedure is to change transmitter batteries first, then the receiver. You have to wait for something like 10 minutes for the units to begin to "talk". All of this should be covered in the instructions you received with your system
Oct 14, 2013 | NG Weather NATIONAL GEOGRAPHIC 265NC
ONLY SHOWS INDOOR TEMPERATURE DOES NOT SHOW OUTDOOR TEMPERATURE
I have a similar device and the instructions say to remove batteries from both units and wait for 10 minutes without pressing any buttons before installing batteries first in the remote unit then the indoor unit. The outdoor and indoor units have to "talk" to each other before getting in the mood to display temperatures.
Feb 03, 2013 | Oregon Scientific Wireless IndoorOutdoor...
(dell mini 10) Changed RAM from 1gb to 2gb, tried start up and got 4 beeps. Changed it back to the old 1gb, start up and still got 4 beeps....What do I do?????! ! ! !
Try this:
Remove all the memory. Remove the battery.. Wait for ~10 seconds. Turn it on using a power adapter without the battery or memory in.. Wait a couple of seconds, let it beep.
Turn it off again Wait for ~10 seconds. Insert the memory you want. Turn it on.
Apr 28, 2011 | Computers & Internet
It keeps showing Err. We've changed the battery and it still keeps showing that.
Try cleaning the interior of the unit with canned compressed air with the straw nozzle attached. After you have removed the battery. It may have a dust and lint buildup in it. Wait about 10 minutes, then take it outside (if it's above freezing) plug in the battery and see if you get the same Error Code.
If you do, then the unit is malfunctioning. You should contact Kidde Technical Service 877-877-7050 for further instructions. The may want you to return it for repair or replacement. Have the Model Number in hand when you call.
Hope this helps solve your problem.
Feb 09, 2011 | Kidde DC Operated Digital Carbon Monoxide...
Changed batteries and the outside temperature still does not show
Bring the outside sensor inside. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the remote sensor. Put the batteries back in the main unit. Do not touch any of the buttons. Wait 10 minutes. If the remote temperature is not showing within 10 minutes, try again. Once the remote temperature is showing, you can set the clock.
Jan 08, 2011 | La Crosse Measuring Tools & Sensors
Fob wont work the locks
I have done this procedure for my peugeot 307, but you can give it a try for your Pug expert and let me know if it works.
Disconnect the battery for 5 minutes then after connecting the battery perform the following steps
1. Turn the Ignition switch to the ON position using your key.
2. Press the LOCK button for 10 seconds. It will set your ECU in programming mode.
3. Remove the key and wait for 10 seconds.
4. Press the buttons on the key repetedly for operation (lock und unlock doors) to synchronise the key signals.
5. Again turn the ignition on and start the engine.
6. Turn the ignition OFF
If fails in step 4, then disconnect the battery and reconnect it and wait about 10 minutes to check the remote. Some new ecu units synchronises itselfs if you disconnect the battery while in programiing mode.
May 23, 2009 | 2005 Peugeot 405
Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Sync Logo
43 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Timllfixit
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
