Cpu usage 100%
im experiencing 100% cpu usage whenever i start up my laptop. it stays at 100% for 15-20 minutes and then the usage goes back to normal, that is, around 1-15%. but for the first 15 20 mins after starting up the laptop i'm unable to use my laptop for anything!! what could be causing this??
  • 87 Answers
You have too many programs queued to run at startup. Click "Start" and then "Run". Type in "MSCONFIG" and hit return.
Click the startup tab and this is a listing of all the programs that load at startup. Keep all your firewall and antivirus programs, but you can shut off just about anything else, like Java Updater, Quicktime, iTunes updater, etc. etc.
Posted on Jun 14, 2009
    President:
  • 778 Answers
Could be an overload of Apps/Programs starting up with windows. There are several good utilities to maintain/tune up windows that will allow you to edit your startup items and stop all additional applications except for Anti Virus and Firewall from starting with Windows. Doing so will not prevent the use of said applications, just keeps them from starting/loading and trying to update every time you start your system. There could be other reasons for the delay/CPU usage but this is the most likely in my opinion. Other than your Security software as mentioned above, you shouldn't be concerned about stopping software from starting with your system as the utilities that allow you to edit your start up items doesn't allow you to cancel any Windows required systems.
  • Frank  Fernandez
    Frank Fernandez Jun 14, 2009
    Or, you can edit these items in Microsoft Configuration Utility as Officedrone1 has so kindly provided you exact instructions on. You will be prompted to restart your computer when done and will see a dialogue box with a box at the lower left to tick and select "Ok" and you won't see it until next time you edit settings in MSCONFIG.
  • Frank  Fernandez
    Add/Edit: You will see the dialogue after reboot.
  • 374 Answers
The number of programmes working at the backend,some you can see at task manager and some you cannot.Try removing any unwanted software or programmes.Check in the add or remove option in control panel if there r don't hesitate. Clean up your disk regularly if you r an internet user.START-ALL PROGRAMS-ACCESSORIES-SYSTEM TOOLS-DISK CLEAN UP.In system tools you'll find DISK DEFRAGMENTER use that too,especially for C drive. There r many programmes that will do all these automatically,search in the Google. The last option is formatting your drive and making a new OS installation.
Constant 100% CPU usage
you have to get safe mode if you have win xp /7 .also need to check malware and remove unwanted start up programs.
Apr 04, 2014 | Toshiba Tecra 9100 Laptops
As soon as i plug in the charger, my laptop's CPU usage shoots to 100% and i am not able to work. it goes slow. can someone help me with this?
Hi there please check the earthing of your plug point because ,laptops & PC run erratically when not given proper power
Sep 29, 2013 | HP Computers & Internet
High CPU usage from interrupts and ACPI.sys
go to bios see if the cpu cap is off or on also go to system in computer and adjust all index options can also try cpu usage controls in control panel
Feb 28, 2013 | Computers & Internet
100% CPU usage
Try to monitor the CPU usage before opening CROME. If it is normal before opening it then there is some process under CROME which takes you CPU usage report to GOOGLE on this. and remove it through Add/Remove programmes under control panel.
Try to use Firefox instead of CROME.
If it happens again then there is some thing wrong with OS( most probabaly Spyware or trozen).
Jul 30, 2009 | Computers & Internet
Compaq Presario R3150US shuts down with IE7, cpu usage goes up
Have you inatalled the latest service pack before you upgraded to IE7?
If not, suggest you un-install IE7, install the service pack, reboot computer and then upgrade to IE7.
If IE7 causes you problems the revert back to IE6.
Nov 30, 2008 | Compaq Presario R3000 Notebook
Computer CPU usage 100% anytime a program is opened and slowsdown
hi, i have written a document to fix this. if u like i can share it with u. check out myblog see if that helps you out. if not message me and i'll help you sort out this. and yes download combofix and run the tool. it will scan for malware,adware and spyware.
Nov 30, 2008 | Sony VAIO PCG-K47 Notebook
My laptop CPU usage is at 100%
yes you are correct that the tmobile has a frequency
The U.S. T-Mobile network predominately uses the GSM/GPRS 1900 MHz frequency-band, making it the largest 1900 MHz network in the United States.
which is 1.9 ghz
try stopping some servicies(WIN XP)
click on start
click on run
type in MSCONFIG
and press enter
you will get system configuration utility
click on services tab
at the bottom there is a box which has a message hide all microsoft servicies
put a checkmark in that box and then uncheck all boxes which you think is not a programe you use
once you do this click on apply
then click on close
you will be asked to restart the system
just restart it
now you will get a message regarding system configuration utility
do put a check mark in the box which says do not show me this message in future
then click n ok
your system should work fine.
Jun 10, 2008 | Computers & Internet
Svchost.exe using 100% CPU at startup
this is an all too common problem with windows services host, but you will have to refer to this site as there are a few things you can try http://ask-leo.com/svchost_and_svchostexe_crashs_cpu_maximization_viruses_exploits_and_more.html
May 29, 2007 | Toshiba Satellite 2400-S251 Notebook
Computers & Internet Logo
300 people viewed this question
Alun Cox
David Payne
David Payne
