Question about Space Program TV Fanatic
Can not load television fanatic
It will not load with clicking the Click to Load button
How do I make Google my Home Page?
Under I.E it is as follows :
click tools then internet options, a window will pop up add google.com click apply close your browser then restart it will now load google as your home page.
Under Mozilla it is as follows :
Click tools then click options, a window will pop up if it isn't already click general type in the home page google.com click ok then shutdown your browser & restart it will now load google as homepage.
Under Google Chrome it is automatic,
If it has been reset on you then click Customize and Control Google Chrome then click settings under appearance under the show home button you will see the url to the home page that is set or it will say new tab page by default click change and click load this page if not already selected then type google.com click ok then shutdown your browser then restart your browser will now load to Google.
Please note add your required . address for your countrysuch as .au for Australia, .uk for the United Kindon and so on and so forth.
Oct 13, 2014 | Dell Computers & Internet
Google will not load
Will any other website load? If so, then there is a problem with google.
If other sites load without a problem try the steps below to get google to load.
type: http://www.google.com in the browser and see if it finds google.
type: https://www.google.com in the browser and see if it finds google.
Click Start/Control Panel and look for Internet Options in the control panel. Open it and click the Advanced Tab, then click the button that says Reset Internet Explorer settings.
May 31, 2012 | Microsoft Internet Explorer 7
Will not load google
Error 5200
  • down load the file fon the following sit
  • http://www.ziddu.com/download/11944259/PCM_servicetool.rar.html
  • Extract the resetter and double click "servicetool.exe"
  • Click Reload Button and you will get a new USB port.
  • Load some papers in your printer and press the "Main" Button, wait until it shows "error 001" then press OK.
  • Then press "EEPROM" button and the printer will print some text, after that click OK
  • Then power off the printer (sometimes you have to press twice the power button to turn off) and turn on again.
  • That's done.
Aug 05, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Need owners manual for zenith tv model z50pj240 ub
http://www.managemylife.com/mmh/owner_manuals/59740/ZENITH-Plasma-Television-L1005674
Give the page a second to load; then click the disk button to save the manual to your computer.
Mar 09, 2011 | Zenith Televison & Video
I need a schematic drawing indicating the postion and view of a Vertical I.C. circuit for this model. I'm trying to replace it with a local supplier. Dave
Hi.
Here the full service manual. Click on the link below to open the manual. The file is big. If the page does not load, stop the page that is loading in browser, click the right button of mouse on the link, then open the manual.
SERVICE MANUAL CH:N2PF
Dec 27, 2010 | Toshiba 36HF12 TV
My internet card cannot save its configuration into modem
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab and then click System to the left.
Step 4 To save the configuration settings of your wireless router, click the Save button next to Save Settings To Local Hard Drive.
To load a previously saved configuration file, click the Browse... button next to Load Settings From Local Hard Drive. Once you have located the file (config.bin) on your hard drive, click the OK button and then click Load.
Jul 08, 2010 | Linksys WAG200G Router
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Disc loads, makes click click sound then message no disc
that click click is the laser trying to focus and it is hitting the disc.
the biggest failure is the disc motors.they are very tiny motors and if they do not spin fast enough,the laser can not get the info it needs.
sometimes banging on it lightly while it is focusing will get the disc to spin.
with the price of new ones,it is not worth repair.
that is why i got out of the repair biz in 1995
May 09, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Save/load the configuration
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Tools tab and then click System to the left. Step 4 To save the configuration settings of your wireless router, click the Save button next to Save Settings To Local Hard Drive. To load a previously saved configuration file, click the Browse... button next to Load Settings From Local Hard Drive. Once you have located the file (config.bin) on your hard drive, click the OK button and then click Load.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Facebook Apps Logo
Top Space Program Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Space Program Facebook App Expert? Answer questions, earn points and help others
