Question about Maytag Neptune Washing Machines
Maytag MAH8700AWW noisy. Bearing?
I have a Maytag MAH8700AWW front load washer that has become noisy. When I turn the drum by hand or when doing clothes, I hear a noise that suggests a bearing in the drum may be bad. The washer works fine except that it has become noisy. This is especially true when in the spin cycle. Is there a bearing in the machine that I can replace? Could my problem be something else? How do I repair this issue? Thank you
  • 1,511 Answers
In some cases it is a simple adjustment of the Levelers. Use a flat level device to check the levels from front to back and side to side. Make certain the Washer and Dryer have a space between them and they do not bang into one another.
Posted on Mar 17, 2014
  • 213 Answers
SOURCE: Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Posted on Nov 20, 2007
SOURCE: Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Posted on Dec 23, 2007
  • 79 Answers
SOURCE: grinding noise
The Neptune bearings are an interesting breed... Maytag wants you to replace the whole outer tub which includes the bearings installed for $180 or so. You can replace the bearings yourself. See www.tonytool.com to see how it is done. The tool costs $379 or so... but it is designed for the service tech. not the d.i.y.er. But watching the video can give you an idea of how to do it yourself. The bearings were available on www.neptunewaxmotor.com for about $35.00. You will also need the Maytag seal kit 12002022 to complete the job whether you decide to replace bearings or the outer tub.
Posted on Jan 05, 2008
Lumpy816
  • 246 Answers
SOURCE: ensignia maytag washer noise
The bearings on Maytag Ensignia's are part of the seals that keep the water in. Once you start hearing the bearings begining to go, you likely will have a leak following shortly thereafter as the bearing greased is washed out by your laundry soap. Up front. This is a procedure that requires specialty tools and takes me about 45-60 minutes to complete. The easiest way to tackel this job is to take your model number (just on the back side of the console) and take it to a local appliance parts store. Ask them for a tub seal kit. (I can't give you a part number since there is no model number listed) but they should be able to pull it up for you. When they bring it up to the front, inside the seal kit is not only step-by-step directions, but also the part numbers for the specialized tools required as well. If you opt to go the repairman route, I'll forewarn you, the company I worked for charged around 250-300 for the repair on this. Send me back a message if you have any troubles or other questions.
Posted on Jul 01, 2008
bestdarngood
  • 3037 Answers
SOURCE: Spin Cycle is very loud on front load washing machine
yes, you can, if you need a place to buy a new bearing, let me know the make and model and I will get you a link to purchase one from
Posted on Sep 04, 2008
Noisy front load maytag washer
Center bearing going bad,Maytags have a history of this and the whole tub will have to be replaced cause the bearing is made no to come out and.it's best to get a extended warranty on all Maytags,the repairman is so busy now days.
Feb 16, 2013 | Maytag Neptune MAH5500B Front Load Washer
Kenmore oasis washer noisy when spinning
Hi, your probably right about the bearing its usually hard to tell untill they have compltely gone have you tried turning the drum by hand to see if it turns smoothly if it does then it could be the motor thats noisy both can be replaced but the drum bearing is a nighmare trust me you need pullers and its hard work.
So try turning the drum by hand and see if you can feel any roughness or catching this would tell you if the drum bearing has gone.
Let me know the outcome ok
May 01, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load washer, model MAH8700AWW, 4-5 years old. At ant low or high speed spin cycle, the drum bangs badly regardless of load size. Why & what can be done to fix this?
Your bearing are broken or wearing out.
Replace the bearings.
This requires taking the whole machine apart and requires special tools.
I would call a appliance repair company in your area.
It can be very expensive to fix.
Maytag machines are not my favorite.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
Progressively louder on spin maytag neptune model# MAH5500BWW serial#C8028996LC
You have a bad rear drum bearing ( unfortunantly , so do I ) . This involves removing the inner drum and outer drum . The complete rear of the outer drum , has to be replaced , due to the bearing is already installed in the new one . Very expensive to have done and very time consuming to do yourself . You probably should invest in a different washer . Front load washer manufacturers , have not come up with a way to support the front of an inner drum as well as supporting the rear also . Until this happens , rear bearing problems and excess expense for repair , will continue to be the downfall of front loading washers .
Nov 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Noisy Servis M9503S
Hi.
Remve the belt, and turn the drum by hand, if it sounds rough or is noisy, then yes the main drum bearings have failed.
It is a DIY job , but can be expensive, probably cheaper to buy new washer if it is more than 3 or 4 years old.
Nov 22, 2008 | Hoover AAA140 Front Load Washer
Very noisy neptune 6500 in spin
rear bearing problem buy new one when you cant stand noise
parts are about 200 and 3-5 hrs lbr maytag charges 500-600 to repair. good luck
Apr 20, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
137 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
