Question about HP Pavilion dv7-1130us laptop
My screen light just turned off, but i can barely see my desktop and the taskbar. what happened?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Sounds like either the ccfl tube died or your inverter died, a easy way to test this is to take a old working laptop, remove the screen bezel on both laptops and dissconnect the plug leading to the screen (usally a pink and white wire cable and connect the cable from the hp to the inverter on the old laptop, power on both laptops and if the hp screen lights up then the inverter on your hp is dead, this is not uncommon on laptops and if you ever get a new laptop try to get one with led backlight technology, if the inverter from the old laptop has the same plugs, put it into the hp, otherwise order a new on
Posted on Jun 14, 2009
Windows start bar has completely gone
Sympton
You cannot see the taskbar (which contains the "Start" button) anywhere on your desktop.
Causes
  1. The taskbar may be hiding at the bottom of the screen after being accidentally resized.
  2. If the presentation display was changed, the taskbar may have moved off of the visible screen (Windows 7 and Vista only).
  3. The taskbar may be set to "Auto-hide" (Windows XP with Service Pack 2 only).
Solutions
  1. Put the mouse pointer on the bottom border of your screen.
    • If the pointer turns into a double-arrow doublearrow.gif, click and drag upwards.
    • If your taskbar isn't hiding at the bottom of the screen, try moving the mouse to the right, left, and top edges, looking for the double-arrow.
  2. Press the Windows logo key and the P key on your keyboard to bring up the presentation display mode options.
    • Make sure "Computer Only" is selected.
    • Use the arrow keys to toggle between options and Enter to select the correct display mode.
  3. Press the Windows key on the keyboard to bring up the Start Menu
    • Right-Click on the taskbar and select Properties.
    • Toggle the 'Auto-Hide the taskbar' checkbox and click Apply.
    • If it is now checked, move the cursor to the bottom, right, left, or top of the screen and the taskbar should re-appear.
    • Repeat step three to return to your original setting.
Dec 04, 2012 | Computers & Internet
Tip
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit <CTRL><ALT><Delete> and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit <Enter>. Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
on May 27, 2010 | Computers & Internet
The start button is found in the upper part of the screen
Your taskbar may have been unlocked and moved to the top of your desktop. I'll continue under that assumption.
  1. Right-click on your taskbar. If checked, un-check 'Lock the Taskbar'. Otherwise, skip to Step 3.
  2. Left-click on your taskbar and drag it to the bottom of your desktop. This is the original position of the taskbar.
  3. Right-click on your taskbar. Check 'Lock the Taskbar'. (OPTIONAL)
Jun 09, 2011 | ASUS LCD Monitor
Windows 7 start bar disappearing
I see that you are having issues with your Taskbar/Startbar disappearing.
I believe that it is just a setting that we may need to change on your windows7.
click on the properties to see the next window settings
male sure that the auto hide is unchecked on this properties window, click on apply then OK this should set everything for your taskbar not to disappear anymore.
and one more thing right click on an open space on your taskbar this should give you other different options
then click on Lock taskbar to see below image
this should prevent changes to happen on your taskbar.
I hope this helps you, have a great day.
Mar 28, 2011 | Computers & Internet
No icons or taskbar after booting.
Have you tried a safe mode boot (press F8 just before the win start screen and choose safe mode) to see what happens and check for the installed programs. Also try in safe mode with network, update yor antivirus and do a full scan.
Stelios.
Feb 20, 2010 | Fujitsu Siemens Stylistic 3400 Tablet PC
My taskbar is not showing after u start the computer
When you say "after u start the computer" you mean before you log in? The taskbar never shows up until you're logged in, so that's the way it's supposed to work.
If you've logged in and you still can't see the taskbar, it's possible that you've configured the taskbar to "auto-hide." To see if that's what's happening, move the mouse all the way to the bottom of the screen, and the taskbar should pop into view. Unless you've moved the taskbar to the top or side - check by moving the mouse all the way to each edge of the screen until you see the taskbar.
Once you see the taskbar, you can right-click either on the "Start" button or on the clock at the opposite end of the taskbar, and select "Properties" from the menu to turn off auto-hide (if you want to - some people like it once they're used to it). If you want to turn it off, pick the "Taskbar" tab on the Properties dialog, and uncheck the "auto-hide the taskbar" checkbox. Then click OK, and the taskbar should stay visible.
Hope this helps.
Oct 06, 2009 | Microsoft Windows XP Home Edition
Black screen on emachine c2881
3 things. If you hit the windows button does the taskbar show on the bottom? Also, right click in the middle of the desktop and click on "Personalize" (Vista) to change the screen saver and see if that fixes your problem. Assuming you can see the "Start" button, do the following: Right click on Start, click Properties, click on the Taskbar tab and make sure the box is checked next to "keep taskbar on top of all windows"
Apr 25, 2009 | Computers & Internet
No Taskbar
The taskbar is always running in Windows Vista. Unlike Windows XP, it can't be unlocked and hidden unless the 'auto-hide' feature is turned on. If 'auto-hide' is on, simply run your cursor along the bottom edge of the screen and the taskbar should pop-up.
To disable auto-hide, after moving your cursor to bring up the taskbar, right click the taskbar and click properties. Then under the Taskbar tab, uncheck auto-hide.
If auto-hide is off, it may indicate that explorer.exe is not running/has crashed. In order to restart explorer.exe you can either
1) Restart
2) Press CTRL+Shift+Escape, File -> New Task and then type in explorer.exe and run
Feb 01, 2009 | Microsoft Windows Vista Ultimate Edition
TASKBAR PROBLEM
*Right click the taskbar and make sure the "Lock the Taskbar" option is NOT ticked
click and hold a blank space of the taskbar and move the cursor to where you would like it to be sitting so if you would like it to run across the bottom of the screen move the cursor while still holding down to the bottom of the screen, this should make it look more like what it should :)
Thanks!
Apr 03, 2008 | Gateway GT4022 PC Desktop
HP Pavilion dv7-1130us laptop Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
