Question about Salter Health & Beauty
1089 BKWHDR Weight scale stopped working
3 Suggested Answers
abrahamangel
  • 5 Answers
SOURCE: Can I adjust the weight on the scales to match my
Adjusting the scale is not a solution but adjusting your weight all in 60 days.
No strees, side effect or bitter drinks but all natural flavour beverages. Tested & trusted ISO 22000-2005.
YES U CAN, ITS BETTER TO BE ON THE SAME PAGE WITH YOUR DOCTOR.
Posted on Oct 14, 2009
SOURCE: My bathroom scales ww35cha stopped working, i
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
done
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
duccotam@yahoo.com.au
Posted on Jan 22, 2010
Need proof of gross combination weight to register in PA
Take it to a weight scale. The scales can be found at truck stops and are called CAT scales. They are used to weight 18 wheelers and other equipment and give a certified printed ticket that will show the gross weight and axle weights. The truck stop will be able to provide instructions on use.
Dec 30, 2015 | Cars & Trucks
Why scales does not show same weight twice
It sounds like the scale is defective. If it was working properly, the situation would be exactly the opposite.... you'd observe that the scale shows the same weight over and over again. This is a common complaint. I contacted a scale manufacturer and he said that digital scales are programmed to show the same weight when the new weight is a difference of 6/10 lb. or less. This is to discourage people from using a scale over and over again in a short period of time. They are just "number shopping."
Mar 03, 2015 | Health & Beauty
How do I get the User button on my Conair Curves scale to work again, so the scale does more than just measure my weight?
You need to press the buttons to use the functions. Do your buttons work properly? Or is that your problem? The manual is available for download at: http://www.conairscales.com/catalog.php?b[1]=1&product_id=437
May 24, 2014 | Conair WW405 Weight Watchers Tracker Scale...
How to calibrate 1000xr us-magnum digital scale
magnum 1000xr pocket scales turns on calibrates goes to different modes but wont show the weight when object placed on the scale,a lock appears in top left of window, is scales broke or do i have to make lock symble dissappear?
May 28, 2011 | Kitchen Appliances - Others
My scale keeps rotating from one set weight to another and never stops?
mcdevito75 here, You can try to replace the battery, and try this, remove the battery-ies, step on and off the scale then re-install battery-ies and see.If nothing works, contact scale manufacturer.
Jun 28, 2010 | Homedics Glass Digital Scale - Advanced...
My bathroom scales ww35cha stopped working, i replaced the battery and now the scales turn on, but do not display a weight when u step on. Instead the weight shows '0'
done
when start use
Now it wook
Have Fun
Nov 16, 2009 | Conair Weight Watchers WW35 Body Fat Glass...
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Health & Beauty Logo
50 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
