Question about Crafts & Hobbies
Playskool express train engine won't run
Circuit board is cracked
2 Suggested Answers
SOURCE: our playskool train will not move forward
Had the same problem - the train at first stopped moving, but still rotated the balls, then later stopped rotating the balls at all. The music still played, though. I found the issue to be a small belt that transfers the motion from the electric motor to the gear system. The belt is tiny (think small rubber band) and lost tension, finally detaching from the system altogether. Getting to it is the difficult part... mind you that taking it apart carries a very high risk of breaking the plastic, so be prepared to scrap the whole thing and buy new.
To fix, start by removing the 7 outside screws to essentially split the train body in half. You'll have to pry off the large green wheel that's opposite the screws (right side of train) - this part carries the highest break risk. Be mindful of a spring (about 1/2 inch diameter) that may go flying - that one goes on the outside of the little inside wheel that moves the balls around.
Once the train is split in half, remove all screws you find, which will allow you to remove the mechanical sections, which includes the battery pack, electric motor, on/off switch, and gear system, including the wheel that moves the balls around. By the time this entire section is lifted off the train body, you'll see where the gears (they're a bit greasy) are attached to the motor towards the bottom of the gearbox. The gearbox itself has 3 or 4 screws to address that will reveal the entire gear system.
I had to take the lower (smaller) gears apart in order to replace the gear belt.
Replace the gear belt with a small rubber band (you'll likely need a small screwdriver to wrap it around the wheels), then re-assemble the gearbox and system. i recommend constantly running the toy with every step to make sure everything's still connected.
with a healthy rubber band/belt in place, the rest of the gear systems will fall into place with enough torque to drive both the train movement and the ball wheel.
good luck
Posted on Oct 23, 2010
Where can I get rubber wheel covers for traction?
Go to Lionel.com for a list of authorized service centers or order directly from Lionel.
Jan 04, 2016 | Hasbro Playskool Poppin Park Roll n Pop...
Engine runs slowly or not at all
CLEAN wheels, roller pickups & track.
Mar 13, 2014 | Lionel The Polar Express Train Set
How to change batteries in a playskool fao schwarz epress train
if its like the peg perego one, the battey that runs the vehicle is under the seat, and the batteries that run the lights and sound are in the smoke stack
Dec 01, 2013 | Peg Perego Santa Fe Express Ride On Train
How do I clean the tracks & wheels to stop the short circuit?
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Nov 13, 2013 | Lionel Trains Holiday Express G Gauge...
Perego Choo Choo will make noise, but won't move
the sounds are run off of a different battery source, check the battery under the seat and make sure that its connected
Apr 06, 2012 | Peg Perego Choo Choo Express Train Set
1988 Playskool Expres Train engine won't run. Light comes on but wheels won't turn. How can I repair it?
i recently restored a playskool express train that my son had, now for my grandson.
The on-off push switch is the yellow button in the smookestack also controlled by the yellow tab on the bottom (the on-off track can stop the train with the tab). If the light is on then perhaps the forward reverse switch (the yellow bar behind the cab needs to be pushed forward or backwards. In the middle might be off. I had to replace the motor, its a common sized DC motor 6V at 15000 RPM w/ 2mm shaft, for toys..
The bigger problem I had was that the battery cover was very finicky in how tight you closed it, and the rubber traction bands for the driving wheels were rotten. I replaced them with 1-5/16" ID x 1/8" O-rings. Still slips a little.
Dec 10, 2011 | Playskool Toys
Remote is not working for my Lionel Holiday Tradition Express Train with new batteries. Any suggestions?
I rewired my train this weekend..it now works on my outdoor setup....I found that the circuit board inside the engine had a blown capacitor and the power transitor was fried. I by passed the engine board found that it only would run backwards....went into the tender and taped into the power from tack bypassing the rectifer... By the way the engine does not start up when one uses the remote...there is a 20 second delay before starting
Nov 27, 2011 | Lionel 11000 Holiday Tradition Express...
There is electricity coming from the tender of the Polar Express O gauge but the engine does not run. Is there somewhere to send it for repair?
Check with the store you purchased it from. If they don't repair trains they should be able to direct to one that does. You're not the first person to need repairs so they will know.
Jan 25, 2011 | Lionel The Polar Express Train Set
No power to track and/or train. Power to Holiday Express Train
Check the power circuit that goes to the track if there is an open circuit, open circuit means, break or cut line that can not flow the current going to the track to give a power to the train, ok.
Nov 27, 2009 | New Bright 384 Holiday Express Animated...
Crafts & Hobbies Logo
64 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
