Question about Onan Microquiet 3600 & 4000 Generator
How do you get to the fuel filter on onan 4k
How to remove fuel filter
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 29 Answers
Left side behind starting solenoid. Several items including solenoid and a few other things including the metal shelf they sit on need to be removed first. Fuel pump & filter sit behind them in the back of the cavity. Try looking with a flashlight & mirror before removing to get an idea, but disconnect all battery power before sticking anything metal in there.
Posted on Aug 25, 2017
    Prodigy:
    An expert who has answered 500 questions.
  • Onan Expert
  • 573 Answers
The fuel filter screws directly into the pump, it is a small in line filter
Posted on Apr 16, 2014
I have onan 4k model# 4KYFA26100K, RV try to start it starts wont stay running, carb looks good oil level good fuse ok
the oil level sensor is a vital piece of equipment to save your engine when the oil level is too low
talk with generator repair shops as the sensor is generic and you may be able to get a good unit that fits another brand
you can test by bypassing it
however check the fuel flow through the metal tap as the corrode internally and block the flow of fuel--especially if you use e-mix fuel
the oil switch is screwed into the sump near the dipstick with 2 wires running back to a small box about the size of a match box
May 10, 2017 | RVs
Troubleshooting onan repair
Check for a bad fuel pump and a clogged fuel filter.
Jul 16, 2014 | Onan-Orderable Cummins Onan 2.8 KV-FA/...
Have a 2.0kva-fr/26119 onan genorator which runs for 5 minutes and stops can you be of any help
If it stops after 5 minutes whether under load or not, and assuming the air filter, plugs, and fuel filter are new and or clean. The fuel pump is suspect. If it is in a motorhome try conencting it to an external fuel source that is at the same height as the generator. Then higher than the generator. If the problem persisits replace the fuel pump. Or just check fuel pump pressure with a gauge. BE CAREFUL do not use an automotive fuel pump Onan have special low pressure pumps, so use OEM part
Nov 13, 2012 | Onan Cummins 300-5332 Generator Switch and...
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Wont keep running after start button is released
If the fuel filter is good and lines are good then it sounds like the fuel is making its way to the carb built trash is stopping the fuel from getting into the engine in order to run. Clean out the carb bowl and clean out the valve stem. I know on the Honda unit the valve stem is removed with the carb bowl then then with a striaght screw driver you can remove the Body once you drop the bowl down with the stem so to clean out the cyclinderical body. Good luck
Jul 28, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Jun 07, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan Microquiet 3600 & 4000 Generator Logo
260 people viewed this question
Top Onan Electrical Supplies Experts
Lawrence Oravetz
bobalix
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
