Question about Dr Oetker Organic's Home
Dr. Oetker kitchen scale
How can I convert ld/oz to gr on the scale?
3 Suggested Answers
SOURCE: i have a set of hanson kitchen scales and i cannot
To switch your Hanson kitchen scales from ounces to grams, press the on/off button until you see the display change to the measuring scale that you require. This change option is ONLY available as you are switching on the scales, so if it already on - switch it off first and start again from scratch. Once you have set it to grams, it will remember your choice for next time, so you don't need to worry that you have to do this every time you switch on.
I hope this helps. Good luck.
Posted on Mar 13, 2010
  • 876 Answers
SOURCE: how do i program prices per lb and oz on quantum scale
You can go to Hobart.com:
http://www.hobartservice.com/main/default.aspx
and create a new user and download a manual.
Posted on Feb 03, 2015
My digiweigh scale reads 0 - LD what's that mean
Hi Douglas 0-LD means your digiweigh scales are in pounds, 0 means no weight and LD means pounds..... The link below shows how to convert LD to KGS (pounds to kilos)
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Mar 26, 2016 | DigiWeigh Measuring Tools & Sensors
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
Scale stopped giving oz, grams, and kilograms.
Get back to the menu by holding 'unit' when powering up.
Set default values to below by hitting unit to increase digits, and z/t to save.
1 - 00 (press 'unit' until 00 is displayed, then press z/t)
2 - 15 (press 'unit' until 15 is displayed, then press z/t)
3 - 00 (press 'unit' until 00 is displayed, then press z/t)
4 - 05 (press 'unit' until 05 is displayed, then press z/t)
It will only save if you see an 'f' display before turning off.
There is a limit to the amount of times the unit can 'flash' to the memory. If you cannot see the 'f' display, the memory is full and you cannot change.
Hope this helps!
Mar 10, 2014 | Kitchen Appliances - Others
I have the Salter Scales model 2040, it is currently sent to oz, do you know how to change to grams as there is only 1 button. thanks
I just had a play with mine as I wanted to change the weight mode too.
The solution is this:
While the machine is OFF, press and hold the button for about 5-10 seconds.
The display will go from 8888 to show the weight measurement (lb oz) at the top of the display.
Press the button to select the weight you want.
You should be able to continue with your baking :o)
Hope this helps
Oct 09, 2010 | Salter 2001 electronic kitchen scale
I have a set of hanson kitchen scales and i cannot change it from fl oz to grams etc
Feb 08, 2010 | Health & Beauty
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
Setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Oct 06, 2009 | Salter Bakers Dream Aquatronic Kitchen...
Home Logo
75 people viewed this question
Top Dr Oetker Organic's Home Experts
Donni Steen
Tom Chichester
Are you a Dr Oetker Organic's Home Expert? Answer questions, earn points and help others
