Question about Jenn-Air JCD2389G Side by Side Refrigerator
Turn off water filter
How to turn off the icemaker to change the filter
    Problem Solver:
  • 15 Answers
Just lift the wire thing on the side of the ice maker. It will click and stay up. It won't stop it mid-cycle. So if it's ready to drop ice wait till it finishes. When you're done just flip it back down.
Posted on Jun 23, 2014
2 Suggested Answers
daytoncomput
  • 1511 Answers
SOURCE: to replace water filter, turn off icemaker how
The wire like switch that hovers above the icemaker needs to be in the up most position. This shuts the water valve off to the ice maker. Remove the maker tray and dump the existing ice. When changing the filter, twist off and remove as per the directions that come with the replacement filter. Hand tighten and do not twist on with a wrench. The rubber seals are soft and make a positive seal with out too much force.
Posted on Mar 17, 2014
To replace water filter, turn off icemaker how
Mar 17, 2014 | Jenn-Air JCD2389G Side by Side...
Refrigerator filter not runnig
follow this steps and fix it. God bless you
is it getting water into the mold?
  • Is there power to the icemaker? (voltage check)
  • Check for cube lodged in ejector arm
    Jul 29, 2013 | managemylife.com
    ICE MAKER NOT WORKING
    Good day!!!!
    The water filter may be plugged with sediment, or you may have low water pressure. The water pressure for icemakers needs to be at least 40 psi, and up to about 120 psi for proper operation. Water filters need to be changed every six months. If you would like to test your water pressure, we have an Icemaker Water Flow Tester available from our website. This will help you to determine if the water pressure at the supply line is high enough for the icemaker to function properly. To determine if your filter is plugged, look for water both before and after the filter. It may be hard to determine if there is water flowing through the filter. Sometimes it is necessary to pull the filter out of the feed line to see if water is flowing from the exit of the filter into the refrigerator or freezer. You can do this over a bucket to catch any dripping water. Some models have a filter bypass plug to help determine if the filter is clogged. If so, you would remove the filter and replace it with the filter bypass plug. Now test your water flow.
    If your refrigerator has a water dispenser, you can hold a large cup or glass under it for 20 seconds. You should have poured about 13-14 oz. of water in that 20 seconds. If the amount is less, try removing the filter and bypassing it. If you now get the 13-14 oz. of water, the filter was clogged and it's time to replace it. If not, you have low water pressure in the line, and your icemaker may not work properly.
    On occasion, the water inlet tube will freeze where it enters the icemaker. This can happen because the water is dripping slowly, or the freezer is just set too cold. A hair blow dryer can be used to thaw this, but be careful around the plastic tubing. You don't want it to crack or deform. You may want to turn the thermostat up a little bit if this is a regular occurrence. If you have a constant, regular drip, you may want to invest in a new water fill valve.
    Another reason that your icemaker may not be making ice is the bail arm along the side of the icemaker. This arm must be in the lowered position for the icemaker to operate. If the arm is stuck up, it has shut the unit off. This is a safety feature of the unit. Normally, if there's too much ice in the bin, the arm will get stuck in the raised position and keep any more water from entering the icemaker. You must lower the arm to begin making more ice.
    I hope this solution will be helpful...
    Thanks for using fixya and don't forget to rate and write a testimonial if it is work..
    Aug 31, 2011 | Refrigerators
    I disconnected icemaker to put in new floor, i hooked it back up, now my icemaker wont make ice. its going thru the motions but water isnt coming in.
    does this unit have a water filter on it. may want to check filter if so alot of times when you turn water off there will be some sediment /trash come through system and could get lodges in line,filter assembly.. change filter out... you may also have some debri at water valve remove water line from vale and then check connection for any sediment prior to reconnecing turn water on to line holding a glass to catch the water. reconnect adn wait 6- 8 hours to see if ice maker fills with water...you can jump ice maker out by removing front cover and advancing timer.
    Jan 02, 2011 | Kenmore Side by Side Refrigerator
    HOW DO I CHANGE THE WATER FILTER - I BELIEVE THAT THE ICE MAKER IS NOT WORKING BECAUSE OF THIS
    The icemaker is probably NOT run through the water filter. Typically the filter is only for the water through the door. Either the water solenoid valve that supplies water to the icemaker is bad or the icemaker is bad.
    Mar 03, 2010 | Maytag MFD2561HE Bottom Freezer French...
    Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
    Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
    Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
    Icemaker not getting water. I came home to find water all over the floor from my refrigerator. I turned the water supply off in back of the unit and a couple days later started investigating. Changed the...
    Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
    The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
    If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
    Enter the model number on one of two websites below to get parts and diagrams for your appliance:
    Appliance Parts From PartSelect
    Appliance Parts Pros
    Feb 18, 2009 | KitchenAid KSCS25FKSS Side by Side...
    Not getting ice
    sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
    Jan 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
    Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator ice getting all stuck together in one big piece looks like there is some water dripping in the ice box, I have changed the water...
    Ice maker does not work
    Turn the icemaker off for 15-20 seconds at the rocker switch on the side of the icemaker body (square white box)Turn switch back on and immediately press the feeler arm (white paddle) in and out three time. This should start a test cycle. If still no water after it runs through a test harvest cycle (will take about 4-5 minutes), remove the icemaker and look at the ring finger size plastic tube that allows water flow into the icemaker. It is probably full of ice (because of a plugged filter or some other water supply interruption -possibly while you were changing the filter). If the tube is iced up warm it up gently with a hair dryer being extra careful not to get drops of water in the hair dryer nozzle. Do NOT use too high of a heat setting as that tube will melt... complicating things unnecessarily
    Dec 19, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
    Jenn-Air JCD2389G Side by Side Refrigerator Logo
    Top Jenn-Air Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
