Question about Sport & Outdoor - Others
Motor no longer seems to work - have already tried new batteries
We have the box and the bell, both in good order. The bell uses batteries to work, but not even new batteries will help to work now. I was told it might be the motor that needs replacing - are you able to help?
  • 1,511 Answers
If the motor is exposed to the elements, rain water may enter the casing and freeze up the motor shaft, brushes, and windings can short out. May need replacing.
Posted on Mar 17, 2014
Packard bell easynote new95 will not charge up or stay turned on. I have tried a new battery and charger but still have the same problem. Can anyone help please.
If you already have replaced your battery then you might need a new charger which is not charging your any battery at all.
Oct 28, 2013 | Packard Bell Computers & Internet
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
When we turn on the TV and converter box, the TV no longer shows Digitalstream on the screen. Also, when we use the digital remote control to change changes, it does not work. I have tried this on two...
The tv Digital Converter box itself it is problems and the causes it dying or dead already.Those capacitors components parts they used in these Digital Converter boxes for as a power sources are not very good components parts.U know basic electronic have all the tools?Yes?Must take the Digital Conveter box aparts and check for dying and dead capacitors components parts as a power sources.These capacitors components parts they're dying or dead they already alway bulges up or puffing up onto it tops.All these capacitors components parts u must have to replace it to save the Digital Converter box to used.Or tries websites like Amazon.com,Ebay.com to buy a new Digital Coverter box to used.Because these boxes no longer on sale by any big box stores or any small ectronics stores either like WALMART,TARGET,BESTBUYS and RADIO SHACKS.Because it is the same things with Anolge tvs too,it is being fazzing out.
Aug 31, 2011 | Philips Magnavox 20MT133S 20" TV
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
When turning the ignition switch fly wheel does not "turn over" (it hesitates). Action taken: -Cleaned air filter -Changed spark plug -Checked battery cables (to ensure connection are...
Try using a set of jumper cables connected across the starter solenoid. Then you will be able to connect the other ends, and see if engine turns over better than it did before.
If it does, then you need a new solenoid. Personally, I prefer to use a Ford type Firewall Solenoid, but it is bigger and you may not have the space. They do seem to last longer than OEM though.
If engine still exhibits same problem, then your battery is low, or is exhausted. Try putting it on a small charger overnight, then retry with key. If still same problem, replace battery since you have already verified that the cabling and connections is in good order.
Jun 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Nikon F55 shows 'Err' when i turn it on. The camera is inactive since. Can anyone help me understand and fix this problem ?
Its quite likely that the film transport motor is dead or at least the camera electronics thinks so. I assume you already tried new batteries. It sounds like a trip to repair shop is in order.
You might also be able to get another F55 body on Ebay to use as a source of parts since these are no longer in production.
Apr 30, 2010 | Nikon N55 35mm SLR Camera
Nikon F4s battery holder
I have always found Nikon to be extremely good with spare parts.
Have you gone to a camera store and asked them to order in a replacement battery holder? This will not be an "on the shelf" item. The camera is 20 odd years old, after all! but I suspect that (after a long wait) you should get your part.
If the camera store will not order in the part, try contacting Nikon direct.
Good luck.
May 20, 2008 | Nikon F4s 35mm SLR Camera
Makita 6337D cordless drill problem
It is possible that the batteries are no longer good. They may need to be changed. These batteries do reach a stage where they no longer hold charge.
On rare occasions I have seen the gear box jam or the motor bearings go defective.
Jerry G.
Apr 01, 2008 | Kitchen Appliances - Others
Lens motor
check the gear box, maybe one of them is broken. Look carefully every gear this is a very common problem in this camera
May 03, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Sport & Outdoor - Others Logo
64 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
