Question about Hitachi 42HDM12 42 in. Plasma Television
42HDM12 IT ONLY SAY 480 720 HDMI HOW DO I SET IT TO 1080I
HITACHI 42HDM12 IT ONLY SAY 480I 720I HDMI HOW DO I SET IT TO 1080 I HAVE AN HD BOX AND CABLE
  • Hitachi Master
  • 3,866 Answers
This is set automatically if your tv supports 1080i and the res is comming in lower there is nothin g you can do to change that. Otherwise its all automatic.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 14, 2009
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
We bought a hitachi 50hxt 16u tv and are unable
tried to replace the HDMI cable then set the right source.check also your box which not working.
Nov 02, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I have a Mitsubishi WD-73737 73-Inch, the picture format keeps changing automatically. for example, the format will be set at 720i wide and it switches back and forth to 720i normal. any ideas?
I've seen that happen on equipment that has automatic signal detection. Usually this option is available when connecting the equipment with an hdmi cable. The setting can either be on the television or the cable/sat box or both. You have to disable the automatic signal detection signal on both the television (if the television has one in the setup hdmi menu if there is one) and on the cable/sat box. Further you have to choose a resolution on the cable/sat box normally 1080i or 720p fixed. Disable the 4:3 override if there is one. Save and lock in the settings and you should be all set.
May 07, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
How can I switch my screen resolution on the Pioneer PDP-4270 from 480i to 720i or 1080i? HDMI cable is connected appropriately. I have tried new HDMI cables, and pressing reset to factory settings along...
Change the resolution on the cable box or satellite box, witch ever you have. A set by itself cannot change the resolution, if the cable is giving you 720p, that's what you'll see for that station. All stations do not transmit in HD. The best picture is only as good as they're giving you.
Dec 19, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Aquos TV is set on 480p. How do I set to 1080?
It determine by the show what u get 420i 720i or 1080i.Want more 1080i must oder HD package from cable or satalite companies
Jan 19, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HOW CAN I TELL IF MY TV IS 720 OR 1080 ALSO HOW CAN I TELL THE MEGA HERTZ
Go to the Magnavox site and look up your set, or do a search on the net for the model number.
I found a spec sheet at: http://www.annunci-qui.com/14/posts/16_Annunci_Audio_tv_foto/103_televisori_e_proiettori/461_MAGNAVOX_50ML8105D_50.html
This set will only work up to true 1080i. It will not work in true true 1080p which is the full HD mode. They don't say it clearly in the specs, but its 1080p mode is an up-converted mode. The cable or satellite box has to be able to handle 1080 modes. For normal viewing in HD this set should be visually very good. Only a Blue Ray DVD player and some other types of gadgets are able to put out a 1080p video signal.
Cable and satellite services are normally in 720i, some are in 720p, and a few specialty feeds are in 1080i. Most satellite and cable TV boxes cannot support anything above 720i.
The lamp life is 4000 hours. The lamp is fairly expensive to replace. I would seriously consider to upgrade to an LCD or Plasma display. The new generation of TV sets are far superior to the DLP types. Whatever type you choose, make sure it can work with true 1080p.
Go in to some of the show rooms and compare a projected type TV (if they still have them) to a true flat screen. All the projected type screens can never achieve the sharpness and aspect ratio accuracy of a flat screen set.
Jerry G.
Dec 16, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Full hd capable, but only functioning in 480. how do i set my monitor to 1080?
i would have to know what type of connection you are using. usually in most hd monitors, the vga plug will only show up to 480i/p and some will show 1080i. DVI will only show 480i/720p/1080i and if it has an HDMI you can get 480i/480p/720i/720p/1080i/1080p. you will also have to set you resolution of your video card to match.
Sep 18, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Will Hitachi 53UWX10B 53 in. Rear ProjectioSupport play station 3
Yes, it will work. Be sure to use input 4 with the 3 rca input cables red/blue/green for video and 2 rca red/white for the sound. You need component video output on the PS3. http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&langId=-1&productId=8198552921665061579&storeId=10151&INT=M:ak is what you need, if you don't have it already. Here's the thing. The PS3 will work on any set. You can hook it up with the yellow wire and red/white wire for standard def. or 480i. The component cables are for 720 and HDMI for 1080. Your set don't have HDMI, it has component input. The service manuel say's it has 720I available. You can see if the front has HDTV sticker..if it does, them for sure it does. Either way, the PS3 will work on your set. I'm 90% sure it's 720i as well.
Dec 24, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Vizio lcd
This model supports the following formats: 1080i, 720p, 720i, 480p, 480i. Most likely it isn't the TV that is not allowing the 1080i resolution but rather your cabling or the inputs that you are using.
Be sure that that you have an HD signal coming into the TV. You may have to upgrade your cable subscription or if you already have the channels sometimes you have to tell your cable box to use 1080. The same goes for DVD players; they often default to only 480 to maximize compatibility.
The other area to check is your cabling. For the best results use HDMI or Component video.
If you have already checked both of these options let me know & I'll try to come up with some other options for you.
Feb 17, 2008 | Vizio GV42L 42 in. LCD Television
Blu-Ray
Talk with salesman of each piece of equipment after consulting
owners manual for each unit..............................T.
May not be possible.....
Nov 20, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Open Questions:
Hitachi 42HDM12 42 in. Plasma Television Logo
243 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
