Hi all i have perkins 1300 series motor :i have changed the lubricating oil of the motor and this problem appeared the motor doesnt run now just few seconds of cranking and then stop plz help me to solve this problem
    Master:
  • 680 Answers
You are in the wrong catagory try automotive.
Terry
Posted on Apr 07, 2014
How to remove starter from a 4 cylinder perkins engine
Search Results
    [PDF]Perkins 4-154 Shop Manual
    www.kp44.org/ftp/Perkins_4-154_Shop_Manual.pdf
    88 Perkins. Engines workshop manual. 4.154. PRINTED lN U.S.A. .... removal, dismantling, assembly or refitting of a part is straightforward ... The ENGINE NUMBER is located on the cylinder ... starter motor, air cleaner, but without clutch. lb kg.
    Reliability built into starter motors - Perkins Engines
    www.perkins.com/en_GB/.../starter-motors.html
    Perkins EnginesYou can rest assured that your genuine replacement starter motor will work ... 4 Cylinder · 6 Cylinder ... You can learn more about these cookies and general information about how to change your cookie settings by visiting our Privacy and Cookies page. ... This need for dependability is why we test each of our starter motors.
Dec 25, 2015 | Cars & Trucks
I have a 680 proform trainer and the motor is very very loud. what do I need to do to fix it?
Try to put some oil in bearing of motor. For oiling the motor bearing you have to open the top cover. Be sure to remove the power before opening the treadmill. Normally bearing makes noise may be because of insufficient lubrication Or the bearing itself is faulty. Check is the lubricating reduces the noise or not. if not then you have to call for a repair man to change the bearing or replace the motor. un the following link you can fin the motor for your treadmill. Be sure that the power is remove before opening. because all treadmill's motor control circuits are live if there is power.
Motor
Ajin
Jul 21, 2012 | Proform Power Series 680 Treadmill Fitness...
Hello: I own a poulan,500 series pushmower. The
Always use HD in any engine, especially small ones. Most regular SAE 30 is HD anyway, but nowadays, some is not with recycling and all. May I recommend synthetic? It will clean the engine, lubricate better, allow the engine to run cooler and possibly guarantee no mechanical breakdowns of the engine due to it's superior lubricating quality. Advance Auto Parts has their house brand oil now available in synthetic. . IF using synthetic you can use a muti-viscosity oil, like SAE10-30, but NOT when using conventional oil. If you are steadfast on using conventional oil, always use HD and use SAE30, not multi-viscosity oil.
Jun 19, 2011 | Poulan "" Push Mower
The drive that pushes the nail will not retract all the way .. only one nail can be fired then manually push drive up so another nail may be chambered
There needs to be a bit of lubrication there...
spray the area with some WD-40 and let it soak...then place a few drops of light motor oil on the driver and then turn it upside down so the oil runs back and lubricates it...
Then it will work...
heatman101
Oct 13, 2010 | Stanley Tools & Hardware - Others
Holmes "16 fan needs to be lubricated. Where do you add oil
No there is no way to lubricate the new cheap fans internally...they are made to run for a bit and then be thrown out...
I have found that by using a thin oil like WD-40 and then positioning the motor so that it runs back the shaft into the motor you can get it to work into the motor. I usually use WD-40 and then follow with a light motor or sewing machine oil. This seems to give a longer solution...
heatman101
May 05, 2010 | Holmes Products HASF1516 Stand (Pedestal)...
Frequent top up and low oil pressure guage.
if the oil need frequent topping up it can only dissapear in 2 ways a leak or the engine is very worn and is burning it.
a worn engine is also a cause for oil presssure dropping once the engine has warmed up probably worn main and big end bearings on the crankshaft as you will know oil is thicker when cold so oil pressure is increased
Nov 18, 2009 | Electrical Supplies
Fan making noise in AC
pls try to lubricate it if it got oiling port as soon as possible. if no port you may change bearing before the damaging motor . also if this type of motor does not have bearings better to change it
May 01, 2009 | Heating & Cooling
Error code 1300
THIS ERROR IS CAUSED BY POLIGON MOTOR OF THE LASER SISTEM. IF YOU CAN GET TO IT, JUST OPEN IT , LUBRICATE DE SHAFT AND YOUR PROBLEM WILL BE SOLVED. GOOD LUCK.
Mar 03, 2008 | Minolta DiALTA Di181 Printer
Mixer motor shut down
Mine did almost the exact same thing one day. I have the Artisian Model, It would do it on any of the lowest speeds. Dont know if this will help you or not but I just ran mine the next day on all the way high with the spash guard on for making whipped cream for about 6 minutes full throttle and for some reason it hasnt went slow and shut itself off since then. Mine is about 7 months old. I called Kitchen Aid but their customer service all of a sudden seems to not know english worth a poo...
Try running yours on full blast for 5 minutes with something simple in the bowl. If its a 250 watt or higher make whipped water out of 2 cups of water and a tablespoon of cornstarch. Run it till you get what looks like whipped cream. Oh yea. Use the Balloon whip. The lubrication in the motor is supposed to last for at least 5 years but I have seen on numerous post's that if you run them on all the way for at least 5 minutes the oil will even out in the motor. Running the mixers at low speed alot will cause the oil inside not to move as freely since the motor doesnt heat up the oil in the gears.
Good luck.
Nov 15, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Typewriter won't return carriage
try wiping the large bar that runs left to right under the carrier with a cloth wet with a light oil and then move the carrier by hand to see if it will free up. Be sure the typewriter is turned off.
Oct 01, 2007 | IBM Wheelwriter 30 Typewriter
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
