Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
How to clean my Hoover steamvac brushes? or
How to clean my Hoover steamvac brushes? or should I just buy new one to replace it?
  • 25 Answers
Http://www.hoover.com/pdfs/manuals/F5914900.pdf
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Posted on Jun 21, 2009
Hoover F7458-900 SteamVac The brushes quit
My Hoover F7458-900 was doing the same thing, brushes not turning and since it is about 7 years old and out of warrenty I decided I had nothing to lose so I took it apart after reading all the other posts on this problem. The brushes are actually turned by a turbine motor (no belts involved) that runs off air produced by the vaccum motor of the unit. The air turns a metal spindle that then turns several nylon gears in the turbin the last of which turns the brushes. The nylon gear that engages with the metal spindle was worn down to the point that it was no longer engaging with it and thus not turning.
The only fix for this problem is to buy a new turbin motor which is not that expensive about $34 plus shipping since they don't sell just the nylon gear. Hope this helps
May 23, 2010 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Broken Brush on Hoover SteamVac Need to order new brushes
Yes you can order a brush block. It comes complete it is around $35. You can buy or order them at any vac shop or call me at my shop and I can ship them out.
Josh 614.868.0799 m-f 9:30-6 sat 10-2
Dec 18, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Clean inside of brushes
Greetings from GoVacuum,
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this probelm.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture, I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose (garden hose2_bing.gif with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If your brushes still wont spin, you may need to replace the brush block itself. Check the model number on your SteamVac which will be located on the back of the Steamvac on a stick with model information. GoVacuum.com does carry ALL of the SteamVac Brush Blocks on our site if you need to buy a new brush block.
Here's a picture on how you can remove these clips;
If this does not fix your problem, there are a few other problems that could be causing this.
Feel free to call me, or email me if you have any questions about your SteamVac, I'm more then happy to diagnose the problem overthe phone / email.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
1-866-468-2288
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
2,319 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
