Question about Kenwood Radio Communications
Need codes for kenwoon tk2212L-1 scanner - Kenwood Radio Communications
    New Friend:
  • 109 Answers
TK2212 is a Portable 2 way radio not a scanner. What is it that you are trying to do with the radio? What codes are you talking about? If you are trying to program the radio you will need software and cable that is available from a Kenwood dealer or sometimes you can purchase the cable on Ebay and get the software from someone on Yahoo user group "Radio programming"
Posted on Apr 17, 2014
I have a1994 chevy lumina apv with a 3800 how do I check the trouble codes myself
YOU NEED CODE SCANNER, THAT WILL CODE SCAN BOTH OBD 1 AND OBD2 CARS ON BOARD COMPUTER SYSTEMS.94 CAR YOU NEED OBD 1 SCANNER YOU HAVE 12 TERMINAL DLC PLUG UP SYSTEM.
Mar 24, 2011 | 1994 Chevrolet Lumina APV
I cleared my scanner pro-82 now how do i program the channels back. the bank1 is blinking and is on channel 1. i do not have any scan codes for local fd/pd in the 78801 area zip code.
For a comprehensive database of active frequencies in your area (they're really NOT codes), visit:
www.RadioReference.com
To program known frequencies into your scanner,
1. Press PGM. PGM appears. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the number keys and DELAY/. to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel.
Your scanner automatically rounds the entered frequency down to the closest valid frequency. For example, if you enter a frequency of 151.473, your scanner accepts it as 151.470.
Press DELAY/.if you want the scanner to pause 2 seconds on this channel before it proceeds to the next channel after a transmission ends. The scanner also stores this setting in the channel.
To program the next channel in sequence, press PGM and repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
BillB
Jan 19, 2010 | Radio Shack Pro-82 Scanner
Can the Symbol LS4804-I400A scanner scan a QR code bar code?
No, this is a Laser Scanner. The laser beam can scan the barcode only in 1 direction (1D Barcodes). For QR Barcode (2D) you would need an Imager (Digital Scanner).
Jul 14, 2009 | Symbol LS 4800 (LS4804-I400A)
Need codes for scanner
http://www.radioreference.com/apps/db/
Apr 16, 2009 | Uniden BC248CLT Base Scanner
Need my p470 symbol scanner to auto enter
It depends on whether you are using a keyboard wedge or a serial connection. Use 123Scan or MCL to make a change to the ADF file that tells the scanner what to do. Then you will have to upload the file to the scanner.
Appending an "Enter" to a scanned bar code
(Keyboard Wedge connection)
Scanned bar code data 04843100Criteria 1 Code type = Any
Criteria 2 Code Length = Any Length
Action 1 Send all that remains Action 2 Send Value Keycode = 7013 <Enter> (String field must be empty)
Output after ADF rule 04843100<Enter>
Note: To have an ADF rule applied to all scanned bar codes, leave the criteria unspecified (Code Type = Any and Code Length = Any Length).
Appending a "Carriage Return Line Feed" to a scanned bar code
(serial connection)
Action 2 Send Value String = \0D\0A
Note: Keycode value is ignored when string field is populated.
Output after ADF rule 04843100<Carriage Return Line Feed>
Dec 25, 2008 | Computers & Internet
Kenwoon kdc_w6537u
Call Kenwood, be prepaired to supply proof of ownership. Or send it to my shop & we can remove the code. Cost $65.00 + s&H
Guy
Dec 17, 2008 | Kenwood Car Audio & Video
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
How do I Program my Uniden Bearcat BC60XLT
i am having trouble programing frequencies into my scanner i need help!!!!!!!!!!!!!!!!!!!
Aug 09, 2008 | Uniden BC60XLT-1 Handheld Scanner
Handheld Symbol LS4000-I100 barcode reader
you need to use the code book (the programmers book) to configure the reader, you need to tell it how to communicate with the PC (bit rate, stop bits etc....)
this code book should have come with the reader...
this book has barcodes on many pages and also configures the types of barcodes that the scanner can read....
if you do not have the code book you can download it from the maufacturers website
Jul 08, 2008 | Symbol PN: LS4000-I100 Laser Scanner...
NEED ACTIVATE READ OF CODE 128 IN NCR 7872 SCANNER
Reset
Defaults
Prog.mode
Hex 1
Hex 7
Hex 1
Hex 1
Hex 0
Save & Reset
Aug 14, 2006 | NCR RealScan 7872 (787220509090) Fixed...
Radio Communications Logo
89 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
