Question about Hitachi 50VS69 50" Projection HDTV
Spot in tv - Hitachi 50VS69 50" Projection HDTV
  • Hitachi Master
  • 1,511 Answers
The spot may be from debris inside the chamber of the TV box. A bug, dust speck, or other material can attach to the inside screen or on a color tube inside of the unit. Do not touch the inside of the Front Screen as it has a special coating and you could damage the screen permanently. Avoid washing with water or sprays that can enter the frame of the screen. Use a cloth with cleaner applied to it and wipe clean, then dry with a soft rag or paper towel.
Posted on Mar 17, 2014
I have a Sharpe LC-60LE600U. The power went out on it. What power board works on that TV. The lower left hand corner has a black spot, too. Will the power board fix the black spot as well?
Power Board wil not fix black spot. the spot is caused from lamp failure. Led strip has at least one LED out, takes out the whole section. Go into trouble shooting to verify. After so many start ups with the black spot, the TV will not turn on in TV mode.
Sep 22, 2016 | Sharp Aquos Televison & Video
Anyone knows where white spots on the screen along the bottom of the tv screen can be coming from
The spots are part of the transmitted signal. Normally they are masked so you don't see them.
Aug 16, 2016 | Sharp LC 70SQ15U 70 inch Aquos 1080p
Black spots tv screen goes away sometimes
Your tv has multiple backlights in it... sounds like one of your inverters are going. Don't be surprised when the tv stops displaying anything at all.
Dec 31, 2013 | Televison & Video
I have several large water spots on the lower right corner of the tv from overspray with windex. Can this be fixed?
Not a good idea to clean tv with windex. Try wet towel dipped in mild soap solution. Make sure all water has been removed and towel is only wet. When tv off, try removing the spots. Turn tv on only after tv dry.
Dec 22, 2013 | Apex Digital LD4088 LCD TV
The picture on my tv has white spots. it is a rear projection tv hd. viore is the brand.
Lets do this, with the tv on go to the menu and if it's still has the white spots, it's most probable to be your dmd board, if the white spots are gone it might be your video board
Jul 05, 2009 | ViewSonic Televison & Video
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
Spots on sreen
Your spots on screen is normal, which is called color spots.Those were often found on crt tube, where discharge to grounding is slow.
Rdgs
Alan
Feb 24, 2008 | Mitsubishi WS-55807 TV
Green Spot On Screen
IN your statement says tv is second hand and also you tried degausser method also. The problem is permanent magnetic field affected your tv set. So the best recovery is fix one button magnet in the affected area.
Aug 08, 2007 | Panasonic CT-34WX54 34" TV
Televison & Video Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
