I'm having a problem inserting my dvds into my tv/dvd combo and wondered if you can help ?
  • 4 Answers
SOURCE: incorrect disc
that means the disc is in the wrong format
Posted on Dec 16, 2007
  • 979 Answers
SOURCE: Dual 19in D19DLCD1905 HD Ready Digital LCD DVD Combi
discs are placed into the unit label side up. If you continue having problems, get thee to a servicer...accordianman
Posted on Feb 15, 2008
  • 9 Answers
SOURCE: RCA 20" TV/DVD Combo - DVD Player says discs not compatible?
Does it work on store bought DVD's?If it does it means it's not compatable with homemade dvd's on pc's or other recorders.If it dose not you have a dirty lens.If a lens cleaning cd doesn't work,the dvd deck has to be replaced,probably exspensive.
Posted on Jan 03, 2009
  • 12 Answers
SOURCE: stuck dvd in sylvania tv combo
ok this is a verry delicate procdure so do this with caution. take the tv and huck it out the window!!!!! that get that #%&#@# outa there hahah jk. ok so just take some plyers and pull the cd disk tray out with them slowly it may cause damage to the disk but just go slow and steady and it wont break the tv
Posted on Feb 01, 2009
gopakumarg43
  • 75581 Answers
SOURCE: why does my combo tv/dvd only play dvds in black and white? is it broken?
Check its settings. Get into its menu, and select picture settings. Set the color system to 'Auto' there. If wrong setting is done there, only B/W picture will be displayed.
Posted on Aug 27, 2012
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
The make of the tv DVD combo is tosumi tom1024. I try to play DVDs. It reads the DVD 3 times then ejects the DVD. I have tried loads of DVDs.
You may be inserting the DVD the wrong way - try flipping it over so that the label is facing you.
Failing that, you may have to set the region that your DVD's are from in the Menu.
Is this a new TV? Have you played DVD's on it before?
Nov 10, 2012 | Televison & Video
I have been playing DVDs without problem for several years on my RCA 20F510TD 20 in. TV/DVD Combo. Now when in the DVD mode, with a disk inserted, the screen comes up with no disk found. What can I do
NOT much you can do---It is a bad optical unit inside the DVD unit---they do not see parts----only the complete DVD portion----much cheaper to go out and buy a DVD player and connect it to the audio and video jacks this unit should have.
Mar 22, 2012 | RCA 20F510TD 20 in. TV/DVD Combo
Hi got an alba dvd/tv combo and dvd player not playing dvds, showing no disc when dvd is inserted,any soulutions
you have 2 fuses one for tv and one for dvd im thinking one of thouse fuses is bad.
Feb 07, 2011 | Televison & Video
Sansui lcdvd200 some of my dvds work on this
Open your unit and clean the lens of your dvd using cotton bud. If that did no work, try to adjust the trimmer located at the pcb of the lens.. There are 2 trimmers whose function is to focus the alignment of the lens. Adjust the right trimmer minimal only using a mini plastic screw clockwise or counterclockwise direction. Be very careful when adjusting the trimmer. Too much adjustment may cause your dvd to not recognize all the discs that you will insert.
May 04, 2010 | Sansui LCDVD200 20 in. TV/DVD Combo
My sylvania tv dvd combo is ejecting the dvds out
Ur injection button function is stuck or malfunction,return it for warenty repair,tries this couple time see if this is the prob.for certian.tries it with other dvd disks.
Aug 13, 2009 | Sylvania LD195SL8 19 in. LCD TV/DVD Combo
My Panasonic TV has a built in DVD player. Won't read the disc- get message
Check and replace the laser pickup unit. It is faulty [Weak]. If you wish to get some details; visit the site linked here. Pull up older posts.
Dec 28, 2017 | Panasonic PV-DF2703 Triple Play 27 in....
Oct 11, 2008 | RCA BD20TF10 20 in. TV/DVD Combo
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
