Jamo volume control dont work on the left side
  • 1,511 Answers
The pot control may have shorted out and needs to be replaced.
Posted on Mar 17, 2014
Replacement remote for Jamo 360 soundbar
Amazon.com: Replacement Remote Control for JAMO TORSTEN 360 ...
https://www.amazon.com/Replacement-Remote-Control-JAMO.../dp/B01E67NI6U
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. *This is NOT an original JAMO remote ...
Replacement Remote Control for JAMO TORSTEN 360 ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls US$38.81 - ‎In stock
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. This is NOT an original JAMO remote ...
jamo replacement remote ' AVForums
https://www.avforums.com > ... > Home Cinema Speakers Oct 5, 2014 - Hello, I have jamo p102 speakers. Unfortunately the remote is broken which means I can't control the speakers at all now. It can't be fixed. Is it... Replacement remote for Jamo 360 soundbar Google Search
Feb 01, 2017 | Jamo Audio Players & Recorders
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
I was given a Jamo sub 1810, but have no instruction manual. I'm trying to hook up to my Pioneer HTP-2500 home theater system. What would be the correct way? Also if you could help me with the setup,...
Find it here...
http://www.jamo.com/na-en/support/owners-manuals/
http://www.jamo.com/images/download/779.aspx
The Jamo is self-amplified and accepts Line Level input ONLY.
The HTP-2500 receiver drives a subwoofer directly with SPEAKER LEVEL output only and does not have a volume-controlled output for driving externally-amplified devices.
May 21, 2011 | Jamo SUB 1810 Subwoofer
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
Jan 08, 2011 | Jamo SUB300BA SUB 300 Powered Subwoofer...
I have bought JAMO sub 250 subwoofer and Pioneer VSX919AH-K amp. Please advise how can I connect them. The amp has one RCA out for sub but the sub has two line in sockets (left and right). Do I need to use...
You don't need such cable, although you can use it if you have one. If receiver has only mono SUB output (as majority of receivers have), you just connect it to the Left socket on the Sub and it will work.
Using the Y cable would probably cause that you will fed the same signal to both left and right sockets, but half the intensity (you would divide the output from receiver by 2). So in the end the Sub would receive exactly the same signal as when using normal straight cable.
Dec 30, 2009 | Jamo SUB 250 Subwoofer
I have a jamo 250 sub and dont know which coax input to use
one will do just fine if you've tried one and its not working try to refer to manual on how to set up in the receiver function menus and if the sub is powered by an external amp which most are
Jul 03, 2009 | Jamo DVR-50 System
Jamo docking station
I Dont Know What To Do On The Docking Station But Carnt You Just Turn It Up And Down Using The Ipod ?
Jan 20, 2008 | Apple iPod nano 3rd Generation
 Grubhead
Grubhead
